I am using lpc2919 board and using ARM REAL VIEW compiler and i face the following problems when i use scanf() statement to get values from serial.
I have included the Retarget.c file as follows
struct __FILE { int handle; /* Add whatever you need here */ }; FILE __stdout; FILE __stdin;
int fputc(int ch, FILE *f) { return (sendchar(ch)); }
int fgetc(FILE *f) {
return (sendchar(getkey())); }
The printf statement works fine with UART1, but when i use the scanf () in my routine i get the following error
Error:L6218E: Undefined symbol __backspace (reffered from__0scanf.o).
I could not find the error in keil help menu.
But when i comment the scanf() in my routnie i dont see any errors like that.What hould i include or configure so that scanf() works on my REAL VIEW ARM compiler. Can anyone send a example code with scanf () routine which reads the input from keyborad.
With regards -Gerardo Diez
http://www.keil.com/forum/docs/thread14866.asp
