Thanks Peter....... My Apology for not putting the
Code in proper format ......
I want to implement the functionality of IAP in LPC2214.... for testing purpose I have taken the sample code from keil..... C:\Keil\ARM\Flash\LPC_IAP_256...In this code I have tried to erase all the sector & write data . I am able to erase all the sectors & write the data successfully.......except sector 0 ? as I try to erase sector 0 and write some data on it ......... it erases all the sectors and not data has been written ? The sample code form keil is ...... As You can see in the main function, we have disable the Interrupt function .........
/* IAP Download Function */
#include "FlashOS.H" // FlashOS Structures
#define M8(adr) (*((volatile unsigned char *) (adr)))
void IAP_download(void);
volatile int ret; // Return Code unsigned char TempBuf[1024] = " CMS CMS CMS "; static unsigned char TempBuf2[1024]; unsigned int Cnt;
void IAP_download (void ) { unsigned long n; unsigned short Cnt; ret = Init(0, 48000000, 1); //ret |= EraseChip();
ret |= EraseSector(0x00000000);
ret |= EraseSector(0x00002000);
ret |= EraseSector(0x00004000);
ret |= EraseSector(0x00006000);
ret |= EraseSector(0x00008000);
ret |= EraseSector(0x0000A000);
ret |= EraseSector(0x0000C000);
ret |= EraseSector(0x0000E000);
ret |= EraseSector(0x00010000);
ret |= EraseSector(0x00020000);
ret |= EraseSector(0x00030000);
ret |= EraseSector(0x00032000);
ret |= EraseSector(0x00034000);
ret |= EraseSector(0x00036000);
ret |= EraseSector(0x00038000);
ret |= EraseSector(0x0003A000);
ret |= EraseSector(0x0003C000);
/* Fill the buffer for writeing in Flash Sector */
for (n = 0; n < 1024; n++)
buf[n] = ( unsigned char )n;
for (Cnt = 0; Cnt <1024; Cnt++)
TempBuf2[Cnt] = '*';
ret |= ProgramPage(0x00000000 ,1024, (unsigned char *)TempBuf2 );
ret |= ProgramPage(0x00002000 ,1024, (unsigned char *)TempBuf2 );
ret |= ProgramPage(0x00004000 ,1024, (unsigned char *)TempBuf2 );
ret |= ProgramPage(0x00006000 ,1024, (unsigned char *)TempBuf );
ret |= ProgramPage(0x00008000 ,1024, (unsigned char *)TempBuf2 );
ret |= ProgramPage(0x0000A000 ,1024, (unsigned char *)TempBuf );
ret |= ProgramPage(0x0000C000 ,1024, (unsigned char *)TempBuf2 );
ret |= ProgramPage(0x0000E000 ,1024, (unsigned char *)TempBuf );
ret |= ProgramPage(0x00010000 ,1024, (unsigned char *)TempBuf2 );
ret |= ProgramPage(0x00020000 ,1024, (unsigned char *)TempBuf );
ret |= ProgramPage(0x00030000 ,1024, (unsigned char *)TempBuf2 );
ret |= ProgramPage(0x00032000 ,1024, (unsigned char *)TempBuf );
ret |= ProgramPage(0x00034000 ,1024, (unsigned char *)TempBuf2 );
ret |= ProgramPage(0x00036000 ,1024, (unsigned char *)TempBuf );
ret |= ProgramPage(0x00038000 ,1024, (unsigned char *)TempBuf2 );
ret |= ProgramPage(0x0003A000 ,1024, (unsigned char *)TempBuf );
ret |= ProgramPage(0x0003C000 ,1024, (unsigned char *)TempBuf2 );
while (1); // Wait forever }
/* Main Function */
#include <lpc21xx.h> #include <stdio.h> #include "FlashOS.H"
extern void IAP_download(void);
int main(void)
IODIR0 = 0xFFFFFFFF;
IODIR1 = 0xFFFFFFFF;
//#pragma arm
VICIntEnClr = 0xFFFFFFFF; // Disable all interrupt IAP_download( );
// #pragma thumb
while (1); }
/* FlashDev.c Function */
struct FlashDevice const FlashDevice =
FLASH_DRV_VERS, // Driver Version, do not modify!
"LPC2000 IAP 256kB Flash", // Device Name
ONCHIP, // Device Type
0x00000000, // Device Start Address
0x0003E000, // Device Size without Boot Loader
// (248kB)
1024, // Programming Page Size
0, // Reserved, must be 0
0xFF, // Initial Content of Erased Memory
100, // Program Page Timeout 100 mSec
3000, // Erase Sector Timeout 3000 mSec
// Specify Size and Address of Sectors
0x002000, 0x000000, // Sector Size 8kB (8 Sectors)
0x010000, 0x010000, // Sector Size 64kB (2 Sectors)
0x002000, 0x030000, // Sector Size 8kB (7 Sectors)
SECTOR_END };
No need to create new threads. It just creates confusion for people reading or answering - remember that Google and other people may not know that the threads are related, or that the discussion has moved to a new thread.
But you still haven't read the text directly above the message input box. If you had, then your code would have looked like (assuming you did indent the code with spaces):
#include <stdio.h> int main(void) { printf("Hello world!\n"); return 0; }
I Have disable all the Interrupt Vector ......... Here is the code for Memory mapping ......what modification has to be done ? in order to erase sector 0 ?
; Memory Mapping (when Interrupt Vectors are in RAM)
MEMMAP EQU 0xE01FC040 ; Memory
Mapping Control
IF :DEF:REMAP
LDR R0, =MEMMAP
IF :DEF:EXTMEM_MODE
MOV R1, #3
ELIF :DEF:RAM_MODE
MOV R1, #2
ELSE
MOV R1, #1
ENDIF
STR R1, [R0]
You still haven't got it right!
When you look at your text in the Preview, does it look right to you?
Does it look like clear, legible, easy-to-read, properly laid-out code to you?
The instructions for posting are very clearly stated - see: www.danlhenry.com/.../keil_code.png and note the red highlight.
Also click the link for "Tips for Posting Messages"...
Thanks I have Got it ........ How to post the new messages.....
Per, have you noticed the colon that precedes your name...?
I have tried this also, but still I am not able to erase sector 0 ?
; Memory Mapping (when Interrupt Vectors are in RAM) MEMMAP EQU 0xE01FC040 ; Memory Mapping Control IF :DEF:REMAP LDR R0, =MEMMAP IF :DEF:RAM_MODE MOV R1, #2 ELSE MOV R1, #1 ENDIF STR R1, [R0] ENDIF
(I don't know anything about LPC22xx, it is special, because it has the ability to run uCLinux.)
I guess, sector 0 is where you put your application?
Thanks Tamir & John .........
I am very happy by the advice suggested by you ....... really .... Just changing the code here and there had not help me .... I have gone through the whole code with conceptually and through understanding .......
Finally I was able to write the full IAP routine successfully ..... .i.e able to erase all the sectors & programmed it......
I am making mistake in placing the code in ROM region, after your advice place the code in IRAM region that write the flash in RAM, right click on your C file, use options to select a RAM region -
groovy!
