Hi all,
I want to design a battery charger simulator which mimicks chargeing a 100Ah 12V battery in about 3 to 4 hrs. it must be in ANSEY C and have separete modules.
Input: 60VAC - 240VAC Frequency: 40Hz - 97Hz Battery: Lead Acid 12V, 100Ah. Charge Time: 3 to 4 hrs.
I made a true charger earlier which take 8-10 hrs. to charge the battery but I require to charge within 4 hrs.
I was thinking of using pulse charging method. But I am not fully aware regarding the mechanism of rapid pulse charging method. Searching internet, I also could not gather adequate working knowledge. If anybody is willing to share knowledge or can provide some link, it will be of great help.
1) Simulator? With modules? Just imulate that you have a higher charge current...
2) What does 60V to 240V have with a simulator to do? These are figures only meaningful for real hardware.
3) Lead-Acid don't muc like being quick-charged.
4) Why up to 97Hz?
5) How does this question relate to the Keil tools?
What does the manufacturer or the Battery say? If you charge outside their spec you take on the testing of Battery life an safety. And I agree this is Very not a Keil Question.
