I2C only works in debug mode
Using STR912
Using the I2C module in debug mode step by step it works fine, I can read and write properly, if I do exacly the same but in run time ... doesn't work anymore.
Is it a frequency issue?
This is my code for the initialization and clock settings:
Initialization of the module:
 // I2C Module initialization
  OutputEnable();
  //I2C0 reset
  I2C_DeInit(I2C0);
  // Enable I2C0
  I2C_Cmd(I2C0, ENABLE);
  // I2C0 Configuration
  I2C_Struct.I2C_GeneralCall = I2C_GeneralCall_Disable;
  I2C_Struct.I2C_Ack = I2C_Ack_Enable;
  I2C_Struct.I2C_CLKSpeed = 100000;
  I2C_Struct.I2C_OwnAddress = 0x00;
  I2C_Init(I2C0, &I2C_Struct);
My general clock definition:
  SCU_MCLKSourceConfig(SCU_MCLK_OSC);
  // Default configuration, wait state insertion :This function should be executed from SRAM when
  //booting from bank1 to avoid  Read-While-Write from the Same Bank.
  FMI_Config(FMI_READ_WAIT_STATE_2, FMI_WRITE_WAIT_STATE_0, FMI_PWD_ENABLE,\
    FMI_LVD_ENABLE, FMI_FREQ_HIGH);// Insert 2 Wait States for read
  SCU_PLLFactorsConfig(192, 25, 2); // PLL factors Configuration based on
  // a OSC/Crystal value = 25Mhz
  SCU_PLLCmd(ENABLE);  // PLL Enable and wait for Locking
  SCU_RCLKDivisorConfig(SCU_RCLK_Div1); // RCLK @96Mhz
  SCU_HCLKDivisorConfig(SCU_HCLK_Div1); // AHB @96Mhz
  SCU_FMICLKDivisorConfig(SCU_FMICLK_Div1);// FMI @96Mhz
  SCU_PCLKDivisorConfig(SCU_PCLK_Div2);  //APB @48Mhz
  SCU_MCLKSourceConfig(SCU_MCLK_PLL);   //MCLK @96Mhz
  // working configuration @ 96 Mhz
