hi all, I want to make a interrupt driven uart for str9 inwhich when it recieves a character it should jump to recieve interrupt handler where i will process somethinh to the character and then it should return to main programme mythis code does not come out from handler please help
#include "91x_lib.h" #include "stdio.h" #include <91x_lib.h> #include <string.h> #include <limits.h> //#include "sio.h" UART_InitTypeDef UART_InitStructure; static void Delay(u32 nCount) { u32 j = 0; for(j = nCount; j != 0; j--); } void main(void) { GPIO_InitTypeDef GPIO_InitStructure; UART_InitTypeDef UART_InitStructure; SCU_APBPeriphClockConfig(__UART0, ENABLE); SCU_APBPeriphClockConfig(__GPIO5, ENABLE); GPIO_DeInit(GPIO5); GPIO_InitStructure.GPIO_Direction = GPIO_PinInput; GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1; GPIO_InitStructure.GPIO_Type = GPIO_Type_PushPull ; GPIO_InitStructure.GPIO_IPConnected = GPIO_IPConnected_Enable; GPIO_InitStructure.GPIO_Alternate = GPIO_InputAlt1 ; GPIO_Init (GPIO5, &GPIO_InitStructure); GPIO_InitStructure.GPIO_Direction = GPIO_PinOutput; GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0; GPIO_InitStructure.GPIO_Type = GPIO_Type_PushPull ; GPIO_InitStructure.GPIO_Alternate = GPIO_OutputAlt3 ; GPIO_Init (GPIO5, &GPIO_InitStructure); UART_DeInit(UART0); UART_InitStructure.UART_WordLength = UART_WordLength_8D; UART_InitStructure.UART_StopBits = UART_StopBits_1; UART_InitStructure.UART_Parity = UART_Parity_No ; UART_InitStructure.UART_BaudRate = 115200; UART_InitStructure.UART_HardwareFlowControl = UART_HardwareFlowControl_None; UART_InitStructure.UART_Mode = UART_Mode_Tx_Rx; UART_InitStructure.UART_FIFO = UART_FIFO_Disable; UART_Init(UART0, &UART_InitStructure); UART_Cmd(UART0, ENABLE); UART_ITConfig(UART0, UART_IT_Receive, ENABLE); SCU_AHBPeriphClockConfig(__VIC,ENABLE); SCU_AHBPeriphReset(__VIC,DISABLE); VIC_DeInit(); VIC_Config(UART0_ITLine, VIC_IRQ, 0); VIC_ITCmd(UART0_ITLine, ENABLE); UART_Cmd(UART0, ENABLE); while(1) { } } int SendChar (int ch) { UART_SendData(UART0, ch); UART_ITConfig(UART0, UART_IT_Transmit,DISABLE); while(UART_GetFlagStatus(UART0, UART_IT_Transmit) !=RESET); return (ch); } int GetKey (void) { while ((UART0->FR & 0x10)); /* RX Fifo Empty */ return (UART0->DR); } /* void UART0_IRQHandler(void) { unsigned char ch; if(UART_GetFlagStatus(UART0, UART_FLAG_RxFIFOEmpty) != SET) { ch = UART0->DR; printf("%c",ch); VIC1->VAR=0x00; } // printf("4"); //printf("5"); } */ void UART0_IRQHandler(void) { unsigned char ch; while (UART_GetFlagStatus(UART0, UART_FLAG_RxFIFOEmpty) != SET) { { UART0->ICR = UART_IT_Receive; /* clear the interrupt*/ ch = UART0->DR; printf("%c",ch); VIC1->VAR = 0; } VIC1->VAR = 0; } VIC1->VAR = 0; /* Acknowledge Interrupt*/ }
