Hi all:
My chip is Cypress 68013 56pin. I am trying to use interrupt in my code. I also use a global variable to be interrupt indicator. The result is : program halt.
I did some test and got something.
1. program run if I remove either global variable or interrupt ISR. 2. program run if I set code rom size option to Small. I don't need to modify anything. ISR, global var are all existed. 3. program halt if I set code rom size option to Compact or Large.
Any one can help me? Thanks
Eric
