Hello, I'm trying to create a elf file with the help of a scatter file. I'm using the RVCT 2.2. This is my scatter file:
LOAD_FLASH 0x100000 0x80000 ; defines begin and size of the load region { FLASH 0x100000 0x80000 ; defines begin and size of the int. Flash execute region { * (Reset, +FIRST) ; interrupt vector has this 'Reset' attribute * (+RO) ; places all remaining Read Only CODE and DATA in this section } IRAM_CODE 0x200000 ; defines begin of the int. Ram region { * (IntCode, +FIRST) ; places code with 'IntCode' attribute exactly at IRAM_BASE * (IntData) ; places data with 'IntData' attribute here } XRAM_CODE 0x20000000 ; defines begin of the ext. Ram execute region { * (ExtCode) ; places code with 'ExtCode' attribute exactly at XRAM_BASE * (ExtData) ; places data with 'ExtData' attribute here * (+RW) ; places all remaining Read/Write Code and Data in this section } XRAM_HEAP +0x0 UNINIT { * (ExtHeap) ; this heap size is defined implicitly via defined variables * (+ZI) } XRAM_STACK 0x21000000 UNINIT ; stack is located on top of memory and grows downward { * (ExtStack) ; this stack size is defined implicitly via defined stack areas in startup code } }
I've also reimplemented the __user_initial_stackheap function (as recommended in linker user guide):
__value_in_regs struct __initial_stackheap __user_initial_stackheap( unsigned R0, unsigned SP, unsigned R2, unsigned SL) { struct __initial_stackheap config; config.heap_base = (unsigned int)&Image$$XRAM_HEAP$$Base; config.heap_limit = (unsigned int)&Image$$XRAM_HEAP$$Limit; config.stack_base = (unsigned int)&Image$$XRAM_STACK$$Base; config.stack_limit = (unsigned int)&Image$$XRAM_STACK$$Limit; return config; }
The linker returns following error:
Error: L6788E: Scatter-loading of execution region IRAM_CODE will cause the contents of execution region XRAM_HEAP to be
corrupted at run-time. Error: L6788E: Scatter-loading of execution region IRAM_CODE will cause the contents of execution region XRAM_HEAP to be
I've no idea what this error causes. Can anyone say what is going wrong here? Thanks in advance,
Greetings Christian
