generic pointers and bad code problem
I have searched the entire knowlege base and have not found an answer to a specfic question.
how do you CAST a generic pointer to a memory specific pointer.
There are examples in the manual for casting a memory specific pointer to a generic, but not the other way around.
Specifically, I have an array of generic pointers to structures. the array is located in xram.
I have found a bug in the compiler where in it gets confused as to what kind of pointer it is dealing with
(more later). If I could type cast the pointer to generic it would most likely fix the problem.
The problem I'm currently up against, is the following where the compiler only generates the 0xFF identifier for a generic pointer when assigning a generic pointer read out of an array, to a generic pointer. to wit:
Below, is an abbreviated source. I'm not sure if this will exhibit the problem if compiled or not, but my code that uses the same lines of code below fails.
Specfically in this example, at address 37F The compiler fails to copy a generic pointer into another generic pointer. All it does is load the memory type specifier into the pointer. This is a 7.5 compiler.
The target part is a silabs 040
very strange problem with indexing and pointers.
Given the following structures, the code below breaks.
Sample values as examined in the silabs debugger show
in xdata, there is an array of pointers that is copied from flash.
After the copy the table looks something like this
32B 32C 32D 32E 32F 330
0xFF 0x02 0x01 0xFF 0x0A 0xB8 the result of the code is that
current_treatment winds up with the following in it. 0xFF 00 00 00
the table is at 0x032B
current_mode = 1;
Here is the listing code. As you can see, this does not copy the pointer, just the type.
Something is clearly wrong here. In other versions of this, that I was debugging prior to compiling this one,
I was seeing it index by 2, and pick up the values that way, which resulted in the current_treatment holding
0x01FF0A2B which is also wrong.
0361 7800 R MOV R0,#LOW current_mode
0363 E2 MOVX A,@R0
0364 FF MOV R7,A // here R7 = 1
0365 33 RLC A // double it
0366 95E0 SUBB A,ACC // results in 0 !
0368 FE MOV R6,A // R6=0
0369 EF MOV A,R7 // ACC now = 1
036A 25E0 ADD A,ACC // ACC now = 2 (should be 3)
036C FF MOV R7,A // R6R7 now are 0002
036D EE MOV A,R6 // since the value is 1, there will be nothing rotated into R6
036E 33 RLC A
036F FE MOV R6,A // R6R7 now are 0002
0370 7400 R MOV A,#LOW treatments // puts 2B into a
0372 2F ADD A,R7 // adds 2 to it resulting in 2D
0373 F582 MOV DPL,A // dp = 002D
0375 7400 R MOV A,#HIGH treatments // this puts 03 into A
0377 3E ADDC A,R6 // adds 0 to it resulting in 03
0378 F583 MOV DPH,A // dptr now is 032D
037A A3 INC DPTR // increments to 032E which is CORRECT
037B E0 MOVX A,@DPTR // picks up the 0xFF
037C 900000 R MOV DPTR,#current_treatment
037F F0 MOVX @DPTR,A // saves 0xFF. and never picks up anyting else ; SOURCE LINE # 2367
0380 ?C0034: ; SOURCE LINE # 2375
0380 120000 R LCALL LCDClearScreen ; SOURCE LINE # 2376
0383 120000 R LCALL L?0870
struct treatment_table idata * current_treatment;
struct treatment_table xdata * scroll_treatment;
code struct treatment_table user_control= { 1, /* only one step */ 0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xff,0xff,0xff,/* infinite time */ };
code struct treatment_table single_pulse_zero_d= { 1, /* only one step */ 0xFF,0xFF,0xFF,0xFF,0xFF, 0xFF,0xFF,0xFF,0xFF,0xff,0xff,0xff,/* infinite time */ };
struct treatment_table xdata * treatments[]= { &user_control, // This is a holder for the user mode. 8-12-08 &single_pulse_zero_d };
// No memory specifier, means that this will be a generic pointer table, so it can point to xram OR code.
// the compiler takes care of this, though it generates much slower code 8-21-08
code struct treatment_table * treatment_tbl[]= { &user_control, // This is a holder for the user mode. 8-12-08 &single_pulse_zero_d };
unsigned char current_mode;
main()
{ current_mode=1;
// copies the treatment table from flash into xram. I can't make the keil compiler do this automatically for me.
// when xdata is examined, there is a table of GENERIC pointers there. Each pointer is 3 bytes long, and starts
// with an 0xFF which is correct, it says that it is a generic pointer to code memory.
// memcpy(treatments,treatment_tbl,sizeof(treatments)); // this works just fine
// This however fails. It indexes treatments by 2 bytes, rather than 3 bytes, so it gets bogus pointers into current
// treatment
// current_treatment is GENERIC pointer. So indexing into an array of generic pointers and assigning one to
// current_treatment SHOULD index by 3's and put the entire pointer there.
current_treatment=treatments[current_mode];
  • struct treatment_table idata * current_treatment;
    Are you sure?
  • well according to the Keil manual, if you don't put
    a data type in front of the pointer, it is considered
    a generic pointer.
    code struct zyzzy * foo // a pointer to code
    xdata struct zyzzy * foo // a pointer to xdata
    struct zyzzy * foo // a generic pointer.
    The code is actually computing the index as if it were a xram specfic pointer (i.e. it multiplies the index by 2) and uses that to index into an array that is clearly an array of 3 byte pointers. THEN: it only picks up ONE byte and puts that to the pointer location. It doe NOT pick up another byte. This behavior just started. I don't know if it is a bug or just what is wrong.
    a generic pointer.
    I suspect you're over-interpreting the manual there. The manual does say what it means if you put a memory class specifier to the extreme left of the type declaration, but I'm reasonably sure it does not state that nothing will happen at all if you put it somewhere else. Basically, historical evolution of the tools pretty much forces Keil to have something happen, no matter where you write "xdata" in a type declaration.
    That said, your example does put a data type in front of the pointer. It doesn't put it to the left of the pointed-to type, but it's still to the left of "the pointer" (i.e. the '*' operator and the variable name).
    Or, put it as a question: what exactly did you think that 'idata' and 'xdata' were doing in those pointer declarations?
  • This pointer
    idata struct treatment_table code * current_treatment;
    says that there is a pointer to CODE located in idata space.
    struct code *foo; says that there is a pointer to CODE, but it is located wherever the keil compiler decides to put it, which is generally speaking data space. BUT it is a specific pointer, so it will be a 2 byte pointer.
    struct *foo; says that there is a GENERIC 3 byte pointer, since there is no memory space specified.
    xdata struct *foo; says there is a GENERIC 3 byte pointer that is specifically stored in xdata.
    The trouble is that in my original code example, an array is created of generic pointers, and that array is copied to xdata. However, indexing into that array and assigning a GENERIC pointer from the array to another GENERIC pointer, indexes the array by 2 bytes, NOT by 3, and on top of that, it picks up ONLY the type byte, resulting the the destination pointer being a null pointer to code space.
  • The trouble is that in my original code example, an array is created of generic pointers, and that array is copied to xdata. However, indexing into that array and assigning a GENERIC pointer from the array to another GENERIC pointer, indexes the array by 2 bytes
    I would imagine that you have forced the compiler to lose track of the memory space information associated with the pointers. You may find that you can rectify the situation with a bit of clever casting, but it seems better to me to avoid the situation entirely.
    I checked an 11 year old copy of the compiler manual as well as the online version and both give examples of the syntax as follows:
    Points to xdata, resides in default memory space:
    char xdata * a;
    Points to xdata, resides in code space:
    char xdata * code a;
    Points to anything (generic), resides in xdata:
    char * xdata a;
    The memory space qualifiers are always placed immediately to either side of the '*'. I think that it was suggested to you that you are invoking ancient compatibility syntax with things like 'xdata char idata *a;' and I think that that suggestion was correct.
    Best stick to the current standard syntax, and best not to try and outsmart the compiler.
  • I don't think it was suggested. I'm not trying to outsmart the compiler. Just get it to do what I need it to do.
    Here is a test file. This compiles, but agian it is not creating an array of generic pointers.
    My original code created the array of generic pointers, but when given an index, it indexed by 2 bytes, not 3 bytes and only picked up the memory type specifier and not the address.
    All I am trying to do is to create an array of generic pointers residing in XRAM, aid pointers need to be capable of pointing to any memory space, and access any of the generic pointers and put it into a generic pointer, and I'm not seeing the compiler do that.
    if I remove the code in front of case1 then it puts that into external memory, but I have not been able to make my main program do that without having to do a memcpy
    #include "C8051F040.h"
    #include "stdlib.h"
    struct example
       unsigned char * name[10];
       unsigned int flags;
    code struct example case1=
       "123456789",
        0xFEED
    code struct example case2=
       "987654321",
        0xDEAD
    xdata struct example case3=
       "987654321",
        0xBEEF
    // array is in code space.
    // This version of the code doesn't create a generic struct array.
    // it creates a 2 byte pointer array, with case 03 haveing an address of 04
    // in code space
    code struct_array[]=
        &case1,
        &case2,
        &case3
    // aray is in data space
    xdata struct_array2[]=
        &case1,
        &case2,
        &case3
    xdata struct example xdata * pointer;
    xdata struct example code * pointer2;
    //idata struct example code * current_treatment; // was code
    //xdata struct example code * scroll_treatment;   // was code
    extern void *memcpy (void *s1, void *s2, int n);// dest, sourc, length
    main()
    unsigned int index;
            memcpy(&case3,&case2,sizeof(struct example));
        index=1;
        pointer=struct_array2[index];
        index=2;
        pointer2=struct_array2[index];
        index=1;
        pointer=struct_array[index];
        index=2;
        pointer2=struct_array[index];
    I've compiled and built this test case using 7.5 of the compiler.
  • reading through your post again, I tried changing the pointers to
    struct example xdata * xdata pointer;
    struct example code * xdata pointer2;
    still no joy. The array is still not an array of generic pointers. And in particular, after the first
    assignment to pointer, it is a NULL pointer, and after the first assignment to pointer 2, it points to the two byte value that it read out of the array. It is still not a generic pointer.
    My second point is that I would happily type cast the damn things to generic, but there is no such cast possible.
  • I did not know how to post source code here when I posted my first post. Here it is again but within the
    pre headers. you will notice that the compiler generates code that pics up the memory type only, and does not pick up the address.
     0xFF 00 00 00
    current_mode = 1;
    0x01FF0A2B
    0363 E2                MOVX    A,@R0
    036E 33                RLC     A
    0380         ?C0034:
    main()
        current_mode=1;
    // treatment
  • struct example
       unsigned int flags;
       "123456789",
        0xFEED
    I'm afraid this code is too buggy to demonstrate much of anything. The struct declaration has an array of 10 pointers to unsigned chars, while the initializer is one array of 10 (implicitly const) chars. That just doesn't match up.
    And you didn't really want 0xFEED to be the initializer for the second char pointer in the array, did you?
  • This pointer
    Care informing us where the documentation says so?
    No. Not only according to the compiler manual, but also by your own arguments, this:
    is not an array of generic pointers. It's an array of pointers to xdata.
    That's not surprising as your declarations are memory specific. You have declared a pointer to xdata residing in xdata and a pointer to code residing in xdata.
    I suggest you (re)read the section in the manual that covers this, it explains it quite clearly.
