Run stack from external Memory
Hello All
I am working on a project using a STR912 ARM9 core microcontroller with 96k internal RAM. I also have a external RAM with 1MB. Since i begin to run low on internal RAM, i want to transfer the whole stack to the external RAM so everything is running from there.
Now i am wondering how to implement this. I am using Keil µVision and the Keil Compiler. In the target options i can specifiy my external RAM but as soon as i declare it as on the only default memory, the code won't execute on the microcontroller anymore.
My guess is that the EMI configuration (it's a c function in my main.c file) needs to be called from the Startup code before the stack gets initialized but i don't really know how to implement this. Has anybody the answer or a example code where this is done ? I searched for this info but haven't found anything.
Oh the startup code i use is the one provided by Keil for the STR912 device.
Thanks for reading
Florian
  • Yes, you need to configure the EMI BEFORE the external memory is used. This will need to be done before __main is called in the startup.s file.
    You should be able to convert your C function to assembly in the startup file without too much trouble.
    If you are having too much trouble, you could call the C function from the startup file directly before you call __main. Just make sure you have at least a small, valid stack in the 96k of RAM and that you do not do anything that would require the setup that __main does to be called (such as counting on the initial value of a variable)
  • Hello
    First let me say thanks for the answer and sorry that i only reply now as i just came back from vacations.
    Are there any examples somewhere where it's shown how to do this ? Since i am a beginner in ARM programming and never had to mess with a startup code before it's not too clear to me how to implement this and i haven't found any example startup code to see how to do this.
    Thanks again.
    Florian
  • Hello
    I tried to call the c-function from the main routine for configuration of the EMI in the startup code but it doesn't work.
    Here is the c-function:
    void EMI_Configuration(void)
            // GPIO7 Configuration
      //configure EMI A16, A17, A18, CS0, CS1 pin GPIO 7.0, 7.1, 7.2, 7.6, 7.7
            GPIO_InitTypeDef        GPIO_InitStructure2;
            EMI_InitTypeDef         EMI_InitStruct;
      GPIO_DeInit(GPIO7);
      GPIO_StructInit(&GPIO_InitStructure2);
      GPIO_InitStructure2.GPIO_Direction = GPIO_PinOutput;
      GPIO_InitStructure2.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 |
                                     GPIO_Pin_7;
      GPIO_InitStructure2.GPIO_Type = GPIO_Type_PushPull;
      GPIO_InitStructure2.GPIO_Alternate = GPIO_OutputAlt2 ;
      GPIO_Init (GPIO7, &GPIO_InitStructure2);
      GPIO_InitStructure2.GPIO_Pin = GPIO_Pin_6;
      GPIO_InitStructure2.GPIO_Alternate = GPIO_OutputAlt3 ;
      GPIO_EMIConfig(ENABLE);
      EMI_DeInit();
      EMI_StructInit(&EMI_InitStruct);
      EMI_InitStruct.EMI_Bank_IDCY = 0x3 ;
      EMI_InitStruct.EMI_Bank_WSTRD = 0x3 ;
      EMI_InitStruct.EMI_Bank_WSTWR = 0x3 ;
      EMI_InitStruct.EMI_Bank_WSTROEN = 0x2;
      EMI_InitStruct.EMI_Bank_WSTWEN = 0x2;
      EMI_InitStruct.EMI_Bank_MemWidth = EMI_Width_HalfWord;
      EMI_InitStruct.EMI_Bank_WriteProtection =  EMI_Bank_NonWriteProtect;
            EMI_Init( EMI_Bank0, &EMI_InitStruct);
      EMI_Init( EMI_Bank1, &EMI_InitStruct);
    And here the call from the startup:
    ; Setup External Memory Interface
            IMPORT EMI_Configuration
            MOV             SP,#0x4000000
            ADD             SP,SP,#0x10000
            LDR             R0, =EMI_Configuration
            BX              R0
    Can anybody tell me where the problem is ? Can i even call a c-function directly from the startup code ? As it's possible with other compilers.
    If it's not possible to call a c-function, has anybody got an example for configuration of the EMI in ASM for the STR9xx device ?
    Thanks for reading
    Florian
  • Just a quick reply - very busy.
    Why not call your function using the BL instruction...?
