flash
Downloading to on-chip Flash on an STR710RZ device results in the following error messages:
Load size error. (Addr:=0x20000000)
Unknown Error
and popup window display:
Cannot Load Flash Programming Algorithm!
so, i create a new Programming Algorithm as follow:
//FlashPrg.c
int Init (unsigned long adr, unsigned long clk, unsigned long fnc) {
  return (0);
int UnInit (unsigned long fnc) {
  return (0);
int EraseChip (void) {
  return (0);                                  // Done
int EraseSector (unsigned long adr) {
  return (0);                                  // Done
int ProgramPage (unsigned long adr, unsigned long sz, unsigned char *buf) {
  return (0);                                  // Done
when i use this new Algorithm download my program, it is Done, and get output message:
Full Chip Erase Done.
Programming Done.
then, i insert a arry in "FlashPrg.c" to make it's code larger:
//FlashPrg.c
const int _buff_[30];
the error message is apear again!
