I have just received an evaluation board (AT91SAM7X256).
As usual, there are a few teething problems...
I am trying to get the LED swing demo to work, but it don't. When I load the project '\AT91SAM7X-BasicTools-KEIL_u3V3_20A-1\AT91SAM7X-BasicTools\compil\BasicSAM7_Keil.Uv2' and then enter DEBUG mode (as instructed) I get the following messages in the 'COMMAND' window...
*** Error: 'C:\Keil\ARM\BIN\AGDIRDI.DLL' not found Include "C:\\AT91SAM7X-EK\\AT91SAM7X256-BasicTools-KEIL_u3V3_20A-1_2\\AT91SAM7X-BasicTools\\compil\\resource\\SAM7_KEIL_RAM.ini" // // File: SAM7_KEIL_RAM.ini // User setup file for KEIL debugger // 1.0 09/Seo/05 JPP : Creation // --------------------------------------------------------- //----------------------------------------------------------------------------- // Remap //--------- FUNC void CheckAndNoRemap(void) { int First,i,pt; First =_RDWORD(0x00000000); //* Read the value at 0x0 i=First+1; _WDWORD(0x00000000,i); pt=_RDWORD(0x00000000); if (i == pt) { printf( "------------------------------- The Remap is done ----------------------------------------\n"); _WDWORD(0x00000000,First); } else { printf( "------------------------------- The Remap is NOT -----------------------------------------\n"); _WDWORD(0xFFFFFF00,0x00000001);//* Toggel RESET The remap } pt=_RDWORD(0x00100000); printf( " ---------------------------------------- 0x00100000:0x%08X\n",pt); pt=_RDWORD(0x00200000); printf( " ---------------------------------------- 0x00200000:0x%08X\n",pt); pt=_RDWORD(0x00000000); printf( " ---------------------------------------- 0x00000000:0x%08X\n",pt); } //----------------------------------------------------------------------------- // Watchdog //------------- // Normally, the Watchdog is enable at the reset for load it's preferable to // Disable. //----------------------------------------------------------------------------- FUNC void Watchdog(void) { //* Watchdog Disable _WDWORD(0xFFFFFD44,0x00008000); // AT91C_BASE_WDTC->WDTC_WDMR= AT91C_SYSC_WDDIS; printf( "------------------------------- Watchdog Disable ----------------------------------------\n"); } //----------------------------------------------------------------------------- // PllSetting //------------------------------- FUNC void PllSetting(void) { // -1- Enabling the Main Oscillator: //*#define AT91C_PMC_MOR ((AT91_REG *) 0xFFFFFC20) // (PMC) Main Oscillator Register //*#define AT91C_PMC_PLLR ((AT91_REG *) 0xFFFFFC2C) // (PMC) PLL Register //*#define AT91C_PMC_MCKR ((AT91_REG *) 0xFFFFFC30) // (PMC) Master Clock Register //*pPMC->PMC_MOR = (( AT91C_CKGR_OSCOUNT & (0x06 <<8) | //0x0000 0600 // AT91C_CKGR_MOSCEN )); //0x0000 0001 _WDWORD(0xFFFFFC20,0x00000601); // -3- Setting PLL and divider: // - div by 5 Fin = 3,6864 =(18,432 / 5) : Mul 25+1: Fout = 95,8464 =(3,6864 *26) // for 96 MHz the erroe is 0.16% Field out NOT USED = 0 // PLLCOUNT pll startup time esrtimate at : 0.844 ms // PLLCOUNT 28 = 0.000844 /(1/32768) // pPMC->PMC_PLLR = ((AT91C_CKGR_DIV & 0x05) | //0x0000 0005 // (AT91C_CKGR_PLLCOUNT & (28<<8)) //0x0000 1C00 // (AT91C_CKGR_MUL & (25<<16))); //0x0019 0000 _WDWORD(0xFFFFFC2C,0x00191C05); // -5- Selection of Master Clock and Processor Clock // select the PLL clock divided by 2 // pPMC->PMC_MCKR = AT91C_PMC_CSS_PLL_CLK | //0x0000 0003 // AT91C_PMC_PRES_CLK_2 ; //0x0000 0004 _WDWORD(0xFFFFFC30,0x00000007); //* #define AT91C_MC_FMR ((AT91_REG *) 0xFFFFFF60) // (MC) MC Flash Mode Register _WDWORD(0xFFFFFF60,0x00000100); printf( "------------------------------- PLL Enable ----------------------------------------\n"); } //----------------------------------------------------------------------------- // Reset the Interrupt Controller //------------------------------- FUNC void AIC(void) { int i,pt; _WDWORD(0xFFFFF124,0xFFFFFFFF); // Mask All interrupt pAic->AIC_IDCR = 0xFFFFFFFF; _WDWORD(0xFFFFF128,0xFFFFFFFF); // Mask All interrupt pAic->AIC_IDCR = 0xFFFFFFFF; // Acknownledge timer interrupt _RDWORD(0xFFFA0020); // #define AT91C_TC0_SR ((AT91_REG *) 0xFFFA0020) // (TC0) Status Register _RDWORD(0xFFFA0060); // #define AT91C_TC1_SR ((AT91_REG *) 0xFFFA0060) // (TC1) Status Register _RDWORD(0xFFFA00A0); // #define AT91C_TC2_SR ((AT91_REG *) 0xFFFA00A0) // (TC2) Status Register // disable peripheral clock Peripheral Clock Disable Register _WDWORD( 0xFFFFFC14,0xFFFFFFFF); for (i=0;i < 8; i++) { pt = _RDWORD(0xFFFFF130); // AT91C_BASE_AIC->AIC_EOICR } printf( "------------------------------- AIC 2 INIT ---------------------------------------------\n"); } //----------------------------------------------------------------------------- // Init all register //------------------------------- FUNC void Init(void) { // Standard register R0 =0; R1 =0; R2 =0; R3 =0; R4 =0; R5 =0; R6 =0; R7=0; R8=0; R9=0; R10 =0; R11 =0; R12 =0; R13 =0; R14 =0; R15 =0; CPSR =0xd3; SPSR =0xd3; } FUNC void Setup (void) { int i; PllSetting(); //* Init AIC AIC(); //* Get the Chip ID (AT91C_DBGU_C1R & AT91C_DBGU_C2R i= _RDWORD(0xFFFFF240); printf( " ---------------------------------------- Chip ID 0x%08X\n",i); i=_RDWORD(0xFFFFF244); printf( " ---------------------------------------- Extention 0x%08X\n",i); i=_RDWORD(0xFFFFFF6C); printf( " ------------------------------------ Flash Version 0x%08X\n",i); //* Watchdog Disable Watchdog(); //* Set the RAM memory at 0x0020 0000 for code AT 0 flash area CheckAndNoRemap(); //* Init register // Init(); } printf( " ---------------------------------------- Start\n"); ---------------------------------------- Start Setup(); // Setup for Ram Area *** function 'PllSetting', error 65, line 67: access violation at 0xFFFFFC20 : no 'write' permission *** function 'Setup', error 65, line 77: access violation at 0xFFFFFC2C : no 'write' permission LOAD Obj_KEIL\BasicSAM7_KEIL INCREMENTAL // Download
My current setup is uVision v3.12a (compiler v2.20a) with the wonderful uLink.
Any ideas/suggestions/comments would be gratefully received.
Regards Marcus.
Fixed...!
In the options, the debugger was not set to Ulink!!
Hope this helps other peoples...
m
