Strange Interrupt leads to Abort Mode
I've got a unexpected problem with Interrupts.
Would be nice to discuss it.
I use Timer0 to have about 16000 fast interrupts (FIQ) per second.
There is a AD-Conversation and a few lines of long long int aritmetic to compute. Inside this FIQ-routine there is a static counter. When it reaches 16000 it is reseted and a Software interrupt (SWI) is generated every second.
The SWI-routine has do to some computations and then to display it all on a special three wire conected display.
The programm does not work with 16000 Timer0 Interrupts per second.
It is terminated by Abort-Mode. This comes a little unexpected to my. The effect is gone if i turn down FIQ frequency downto 100Hz. Is it possible that interrupts create a stack overflow?
Should i post my code?
  • How do you expect that your SWI will be finished in 1/16000th of a second, i.e. when it is time for the next FIQ? Remember, you only have 62.5us in total for both FIQ and SWI.
    You only require one result/second to be displayed, so why not let your main loop handle the display output whenever it sees the flag that the FIQ has collected 16000 samples?
  • Soory,
    was my fault. I didn't explained that the SWI leads to IRQ. I expect that the FIQ can interrupt the IRQ. Isn't it so?
  • Here's the code:
    void FIQ_Handler()__fiq __ram
            static long long unsigned int ACC1,ACC2,ACC3;
            static unsigned int int_counter;
            T0CLRI = 0;
            ADCCON = 0x6A3;                 // software conv., single-ended, conv. enabled
            while (!ADCSTA){}               // wait for end of conversion
            ACC1 += ADCDAT >> 16;
            ACC2 += ACC1;
            ACC3 += ACC2;
            if (!(int_counter++ & 0x3FFF)) // every 16384
                    SWICFG = 2; // create a softwareinterrupt
                    ACC3_transfer = ACC3;
    void IRQ_Handler()__irq
            static long long unsigned int ACC3D,D1,D2,D3,D1D,D2D;
            char text[10];
            D1 = ACC3_transfer - ACC3D;
            D2 = D1 - D1D;
            D3 = D2 - D2D;
            ACC3D = ACC3_transfer;
            D1D = D1;
            D2D = D2;
            sprintf(text,"%8.d",(D3 * 125) >> 27);
            SDA5708_printf(text);
            SWICFG = 0; // clear softwareinterrupt BIT
    The sence of this floating average computation is to increase resolution of my 12 Bit AD-Conversation while distortions are decreased.
    YEAH it works properly with lower rates. But with higher rates, 16384 for example, my arm likes to have a vacation in abort mode. :-)
  • You have given a bit too little information about what you do.
    But the SWI is not an interrupt flag that will start when the FIQ handler ends. The SWI is an instruction that will immediately (unless interrupts are enabled and an interrupt occurrs before the SWI instruction is executed) make the ARM enter the SVC mode. So if your FIQ handler executes the SWI instruction, the application with enter the SVC mode and start processing the SWI while still being in the FIQ handler. If you have enabled recursive FIQ before the SWI instruction, then you will nest a second FIQ interrupt.
    If you want to, you can fake a low-priority interrupt from your FIQ handler, and let this IRQ handler perform the display output. But unless your code supports nested IRQ, all other interrupts (except FIQ) will be blocked until the display output is done.
    Because of this, it is best to do all time-consuming operations in the main loop - possibly in a separate thread in case you use an RTOS.
  • George,
    You are probably generating the SWI in the FIQ to speed up the handling of the results. But, at the same time you have the following instruction in the FIQ handler:
    Have you measured the duration of the loop?
    In addition, if your FIQ handler generates a SWI, and the SWI generates an IRQ as you asserted (probably by setting the IRQ flag, then returning immediately?), then the FIQ and IRQ handling are asynchronous - how can you guarantee the integrity of the displayed results without a buffer?
  • George,
    I would like to take back what I said about the data integrity. that was clearly wrong!
  • George,
    I think you are indeed risking data corruption. If your FIQ generates a SWI, which sets an IRQ flag and returns, the next FIQ might interrupt your IRQ while it is doing its job.
  • hi Per and everyone else,
    thanks for your kind reply.
    There is no more information that i can give about my little project, just the code to initialize Timer and interrupt. At this time, the Main programm is just like
    int main(void)
        init_ADC();
        Timer_0_init();
        interrupt_init();
        while(1) {} //now endlessloop, but later important stuff
    void Timer_0_init(void)
            T0LD  = 1632 - 1;
            T0CON = 0xC8;           // Enabled,Periodic,Clock/256
    void interrupt_init(void)
        FIQEN = RTOS_TIMER_BIT; // Timer_0
        IRQEN = SWI_BIT;
    My idea when i wrote this was, the Timer_0 calls FIQ 16000 times per second. Inside FIQ there is a routine that makes a IRQ call every second. The IRQ drives the 3-wire-display, it can and should be interrupted by FIQ. I have no idea what this SVC-Mode is, maybe i have to read the whole DDI0029G ARM7TDMI Technical Reference Manual and DDI0100E ARM Architekture Reference Manual? I'am afraid of doing this!
  • Sorry, the code i posted is the actual version.
    The main clock frequency is 32768 * 1275 = 41779200 Hz.
    The Timer_0 prescaler makes a division by 256 (41779200 / 256 = 163200).
    So a T0LD register value of "1632" leads to a 100Hz interrupt frequency. At this rate, there is no "running into Abort-Mode-Problem". But my goal was to have an average with 16000 ADC-samples.
    SOS need further assistant urgently ;-)
  • George,
    your
    ACC3_transfer
    is not interrupt safe. You would need to disable IRQ and FIQ when working with it.
  • My recommendation is to have the FIQ copy the relevant data once/second and then have the main loop - or a dedicated task - perform the display output. A three-wire interface to the display means that it will take somewhile to output the data. Leave that to the main loop.
    Have you measured how long it take to emit the data to the display?
    Have you measured how large % of your CPU power that is consumed just by the FIQ when running 16kHz? All time lost to the FIQ is extra calendar time needed for the display output unless you can issue a single transfer to the display and then let the hw handle all output.
    You mention SWI. By that, I assumed that you meant the specific instruction used to enter the SVC mode. This is normally done by declaring functions like:
    void __swi(0) my_handler(params);
    void __SWI_0            (params) {
    But I see now that you instead mean that you manaully assert a normal interrupt, and let the processor enter this interrupt as soon as it leaves the FIQ handler.
    Then no SVC mode will be involved. However, have you made sure that the IRQ stack is large enough to support the printf() call?
    Another thing: You start an ADC conversion in the FIQ handler, and then spend time waiting for the answer. Don't do that. Get the existing ADC value and then start a new transfer. Then the interval between the FIQ interrupts will be used for the conversion. 16000 times the dummy wait for a conversion is just lost CPU power - potentially more CPU power than you have...
    Tamir: The transfer should not need to be interrupt-safe. The FIQ only performs the update once/second, and then issues a request to activate the reader. As long as the reader - the display output code - is guaranteed to finish within one second of being trigged, there should be no need for extra protection.
  • Per,
    you are right. I built my own scenario based on the text description, rather than to look carefully at the code.
  • Thanks you all for your help. :-)
    At this time my modified code works.
    I cannceled this SWI-stuff.
    I just put the 3-wire-display in the main-loop.
    The FIQ-routine sets a flag after 16384 ADC-samplings.
    The main-routine watches this flag, does a 3-wire-display-output and resets the flag.
  • char text[10];
    George, remember that "%8.d" is a minimum width specifier, not a maximum and that D3 is a 64 bit integer that is probably increasing in value with the number of FIQs.
    A 64 bit integer is then being shifted right by 27 bits before being passed to sprintf (who is probably looking at it as a 32 bit integer but it can be still big enough to cause an overflow in your 10 character buffer).
    I'd guess would be that you will get a pre-fetch abort when sprintf tries to return to IRQ_Handler because the buffer overflow on "text" trashes the LR that sprintf pushed to the stack.
