Adding Ttl I/o Question/dilema
Hello All,
If anybody has ever looked through the spec document, chapter 8 talks about parallel io. There is a subsection that talks about how to go ahead and add additional TTL I/O using the CE . For the chip, CE is not available (according to the api) so the CE method is what I am trying to implement.
I have built the circuit minus the decoder since I will not be needing the address bus. There is an example program and layout they list to test the additional circuit and mine is not working. I have been able to see with an oscilloscope the CE signal working as well as the write signal. PSEN does nothing when I run the simple test program. I know PSEN is connected properly since it does things when slush is booting up. Has anybody tried to implement the circuit that I have mentioned? I appreciated any response.
DJNOCLUE
