Assign Command
Can you please explain the usage of the Assign command in the debug mode. The notes in microvision help aren't very clear.I couldn't understand the <inreg> , outreg part.
Could someone please elaborate on it with illustrations.
Thanks. :)
  • Go to your Complete User's Guide and search on ASSIGN(all caps). It gives complete functions of the command plus examples. Basiclly the ASSIGN command in the debugger allows the user to re-direct serial communications to the PC hardware serial port. If like me, you have a laptop with no serial port, you may or may not be able to use a USB to serial adapter as your comm port. I have some that work well and others that will not work at all.
    Bradford
