REFERENCE THE THREAD: http://www.keil.com/forum/docs/thread11961.asp
BTW "the bible" is 20+ years old and I have yet to see someone point out an error in it. -- erik malund
The 'Bible' www.nxp.com/.../80C51_FAM_HARDWARE_1.pdf
This looked too much like a challenge, so I had to bite on that bait.
This is almost an error. At least by an Error-by-omission in clarity... "An Error In Clarity."
"THE BIBLE" quote: [On "How Interrupts Are Handled," p16 last paragraph of hardware pdf] The polling cycle is repeated with each machine cycle, and the values polled are the values that were present at S5P2 of the previous machine cycle. Note that if an interrupt flag is active but not being responded to for one of the above conditions, if the flag is not still active when the blocking condition is removed, the denied interrupt will not be serviced. In other words, the fact that the interrupt flag was once active but not serviced is not remembered. Every polling cycle is new. [On p18 "External Interrupts" second paragraph of the hardware manual] Since the external interrupt pins are sampled once each machine cycle, an input high or low should hold for at least 12 oscillator periods to ensure sampling. If the external interrupt is transition-activated, the external source has to hold the request pin high for at least one cycle, and then hold it low for at least one cycle. This is done to ensure that the transition is seen so that interrupt request flag IEx will be set. IEx will be automatically cleared by the CPU when the service routine is called
Do you realize what that means?
I had to figure it out the hard way while using the Intel "Old-Testament" in which this point was not exactly clear and you had to read-between-the-lines [several times] in order to understand how they implemented the interrupt engine. The verbage was carefully crafted.
At least this New Testament "Bible" by Philips alludes to the core problem with the 8051 interrupt architecture's state machine.
A bit of history first: I had discovered this during a rather High Profile & High Stress $700M military contract award competition in which I had to resolve the issue ('with extreme prejudice')
if( PROBLEM != FIXED ) printf( "You owe us $700,000,000\n" ); // Stick else printf( "Dinner is on us tonight.\n" );// Carrot
I finally found it, and then called Intel and spoke with their 8051 engineers (you could actually speak to them back then). After some discussions, they verbally confirmed the problem, but would not put it in writing for the formal government Corrective Action Report. (I put this denial to-write-it-down into the official report). Intel then published the issue in their data books a year or two later.
It is clearly identified in a 1994 book I have. Subsequent MCS-51 books did start to obscure the clarity, and your New Testament 'bible' seems to have killed off the clarity almost entirely.
I have not tested this problem in all of the various vendor implementations of the Intel core, but I wouldn't doubt if many still have this inherent problem. So, beware...
By having the "S5P2" sampling the interrupt source signal and it being anew on each cycle, an EDGE-TRIGGERED interrupt signal can be ignored entirely if the MCU is currently servicing a higher-priority interrupt.
This is caused by the edge being detected in a cycle (actually its a cycle-pair where the first S5P2 samples a high, and the second S5P2 samples the low transition), but is blocked by the high-priority process.
Once it is blocked by the higher priority process (and not simply the RET/LCALL/RETI/DIV type interrupt postponers) 'detection' is essentially cleared in the following cycles because of the non-change of state between the subsequent "S5P2" samplings. Every polling cycle is new.
At least this 'bible' contains the information to derive the issue. But I still consider it an Error since they don't come right out and state what it means.
It is actually fairly easy to fix within the device, but Intel chose to modify the data-sheet instead of issuing an errata and then rev-ing the die.
So, seek your vendor specific data-sheets and not just rely on this 'bible' for all of your 8051 problems. They/we refer to the Philips NXP data-book set as "The Bible," because it is one of the most comprehensive data-books you can get online for the MCS-51 architecture.
I suspect that the single-cycle core variants have a higher probability of a fix in this area since they had to re-engineer the cycle-sampling state machine interrupt engine anyway. (for those who are doing their own 8051 cores in VHDL, you should review this portion of the controller).
In Intel info that states this issue CLEARLY (while the Philips New Testament 'Bible' does not):
From page 21 of Intel's own "83C51KB Hardware Description Addendum to the MCS-51 Microcontroller Family User's Manual" (Order Number: 272801-001 January, 1996) The polling cycle is repeated with each machine cycle, and the values polled are the values that were present at S5P2 of the previous machine cycle. If the interrupt flag for a level-sensitive external interrupt is active but not being responded to for one of the above conditions and is not still active when the blocking condition is removed, the denied interrupt will not be serviced. In other words, the fact that the interrupt flag was once active but not serviced is not remembered. Every polling cycle is new. (It is also present in ORDER NO.: 272383-002 FEBRUARY 1994)
But just remember, the "Edge-Triggered" mode is just an added feature to the MCS-51 capability and not some fundamental core [error].
--Cpt. Vince Foster c/o VRWC (founding member) 2nd Cannon Place Fort Marcy Park, VA
This is almost an error. At least by an Error-by-omission in clarity... "An Error In Clarity." you first quote is the 'general' interrupt, the second is the "edge triggered interrupt special".
While I agree it is a bit 'fuzzy' I wish all techwriters would be as clear at the writer(s) of "the bible".
Anyhow, I have no problem with your findings but if 'fuzziness' is an error, I will challenge you back to find any datasheet where less fuzziness can be found than in "the bible"
PS I have the Intel book, but the Philips version is .pdf and downloadable and searchable.
It is ironic that the scriptural "Bible" is used as a metaphor for accuracy in a highly objective area such as microcontroller programming & operation. An honest examination of this patchwork of ancient Semitic mythology will reveal numerous falsehoods, contradictions, intentional & intentional translation inaccuracies & outright garbage.
Mr. Iverson,
Yes, I get your perceived irony assertion, but...
Think of it this way, the data-book is a resource to solve problems, or to find a baseline from which to measure *your* problem. It serves as our first line of 'truth' about the 8051, while each variant might deviate from this baseline, if you understand the [principal] operations of the MCS-51 controller, you can then interpret any 'new and improved' variants and possibly how you've errored in your application.
The Bible (real) has historically served that same purpose in providing a baseline of 'morality' and insight into human behaviors. A data-book is, by design, meant to be un-ambiguous, while the Bible is open to interpretation (hence "ambiguous") either by design or not. It doesn't matter if the 'trueness' of the two books achieve parity, but rather the social acceptance of the Symbol of Truth. The Bible has that association (again--it doesn't matter if you think it is true, it is its persona that matters here), and the Philips MCS-51 data-book is referred to as the Bible for that same socially accepted persona.
Your *need* to call the Bible a "patchwork of ancient Semitic mythology" misses the point. Although this thread is not a Bible Study program, it does bring up a pet peeve of mine. I take issue with people yappin' and complaining about something and feeling passionate enough to issue harsh opinions, while at the same time they lack the depth about the topic to support such harsh opinions.
I do not know your depth of knowledge on either book, but your reference to 'garbage' indicates you don't get the basic idea about one of the two. Again, I'm not disputing your assertion (I have my own opinions), but rather the vantage point of your apparent ignorance and your harsh opinion of it. [You had pressed my Pet-Peeve Button].
What do I expect as a response? Either none (preferred) or a QUICK note on your bonafides to justify your learned position (of which I will accepted and not retort). We don't need/want a theological discussion on why you think A vs B. This is not such a forum.
erik,
The 'general interrupt' quote contains the information that is in the bible and the readers are supposed to 'get' it from that passage alone.
The 'problem' is more succinctly stated in the "edge triggered interrupt special" quote that is not in the Philips Bible, but rather an older Intel data-book (referred to as The Old Testament, Mr. Iverson).
What makes this an "Error" is the fact that it is not clearly stated as it should be, and has been known for a long time. It is as if they intentionally obscured the information as to hide a fundamental flaw in their 'edge-triggered' interrupt 'feature.' If a data sheet is 'Fuzzy' enough not to tell you that your 3.3v tiny-logic XOR gate requires four amps to operate, I think you could classify that as a data-sheet error. And the word 'error' is being nice: a Data-Sheet Lie might be more to the point.
When the controller data-book says "You can have a gazillion interrupt sources of various priorities, and you can even have edge- or level- triggered external interrupts" but fails to tell you that certain combinations--that would be a common configuration--will not work, then I'll call that an 'error' and not just fuzzyness.
Overall, The Bible has been a very solid source of information and we are hard-pressed to find an 'error' in it. As to your challenge on finding a less fuzzyness data-sheet than the bible, that is would be very hard (other than some resistor spec).
Also, I have--and covet--my Intel 1983 MCS-51 data-book I got when the "CMOS" version of the 8051 first came out. "Covet" in this sense is not a sin, but I think my need to light candles around it's special bookshelf and chant in Ancient Assembler might be.
I guess I should have emphasized that I think that the analogy to the bible profanes the Intel document & not the other way around. I possess a 1988 version of "The 8-Bit Embedded Controller Handbook & an an "advance" version of the 87C51 data sheet (circa 1988). I also have owned since 1984 (until it recently became totally unsupportable) & frequently used, an original Intel iPDS 100 development system, running Intel ISIS II with a 4K 8751 bond-out based emulator pod.
As to the other volume; my only "need" to "yap" about its demonstrable errors stems from social obligation to oppose the current tendency to formulate public policy based on popular misinterpretations by those who eclectically cite what suits them & overlook the many less palatable, contradictory & inconvenient passages within.
I believe that I am as well or better read in at least the "King James version" & "The New English Bible" than most lay persons & also have digested many of the objective analyses offered by qualified critical scholars.
Lastly, let me say the the term "garbage" is none too excessive to apply to the biblical accounts of land theft, assassination, mass murder, torture, child molestation, incest, rape, polygamy, human sacrifice, malfeasance in office, treachery, deceit, mystical prophecy, envy, et al that are found throughout, especially in the "Old Testament".
Need citations?
Lastly +, let me further say that an errata sheet is long overdue for the scriptural bible.
