measuring time between two events ...?????
Hi there...
I would like to measure the time between two events.
I think, I must use a timer in "counter mode"
If I am on the right track..here goes my code:
#include <REG167.H>
#include <stdio.h>
sbit DP2_0 = DP2^0;
sbit DP2_1 = DP2^1;
sbit L_SWITCH = P2^0;
sbit R_SWITCH = P2^1;
void main(void)
{ T3CON = 0x0009;// as counter T3R = 1; //start timer
while(1) { if(L_SWITCH== 0)//if left switched is pressed {
T3R = 1; //start timer T3UD = 0; // Count up T3IN = L_SWITCH; // input from ext
printf("COunter started"); }
if(R_SWITCH== 0) { T3R=0; //stop timer printf("Counter = %3u\r",T3); } }
</b >
Problem I guess is "T3IN".....in debugger it's not getting activated n hence the output is always 0...
Would appreciate if get an expert opinion.
Thanx.
Amit
