Having problems in programming my lcd
i have tried programming my lcd but it does not work and i cant understand were i have gone wrong with my code,
,my code is shown belw
;; Application Note:
; Displaying Characters on an LCD Character Module
; ; Description: Demo software to display “cannedâ€
;message and custom characters.
; Controller: Phillips 87C751
; LCD controller: HD44780, KS0066, SED1278
; Constant Definition
; Port Connections
; P1.0 -> D0
; P1.1 -> D1
; P1.2 -> D2
; P1.7 -> D7
; P2.2 -> Enable
; P2.0 -> RS
; P2.1 -> RW
; Interrupt Vectors
org 000h
jmp PowerUp ; Power up reset vector
PowerUp:
; LCD Initialization Routine
cinit: clr P3.1 ;RS low
clr P2.1 ;RW low
setb P2.2 ;Enable
mov p1,#38h
acall command_byte
acall ddelay ;initial delay 4.1mSec
mov p1,#38h ;function set
acall command_byte
acall ddelay ;busy flag not avail. yet
acall command_byte
mov p1,#0ch ;display on
acall command_byte
mov p1,#01h ;clear display
acall command_byte
acall cgram ;define custom fonts
acall first_line ;display first line
acall second_line ;display second line
sdone:
jmp sdone
;Subroutine: WRITE
;Purpose: To feed in data/command bytes to the LCD module
;Parameters:dptr = should be set to the beginning of
; the data byte address
; Data bytes should be finished with 99H
;Alg: get a new data/command byte
; while (new data != 99h) {
; set port1 with new data
; call data_byte
; increment data pointer
; return
write:
write_loop:
mov a,#0
movc a,@a+dptr
cjne a,#99h,write_cont
ret
write_cont:
mov p1,a
acall data_byte
inc dptr
jmp write_loop
; Delay Routine:
; Delay periond = Ims
ddelay: PUSH ACC MOV A,#0A6H
MD_OLP: INC A NOP NOP NOP NOP NOP NOP NOP NOP JNZ MD_OLP NOP POP ACC RET
MADELAY: PUSH ACC MOV A,#036H
MAD_OLP: INC A NOP NOP NOP NOP NOP NOP NOP NOP JNZ MAD_OLP NOP POP ACC
ret
; set address to beginning
; of CG RAM
cgram:
mov p1,#40h
acall command_byte
mov dptr,#cgram_data
acall write
ret
; Set DDRAM to the beginnig of
; the first line - 00
first_line:
mov p1,#080h ;set DDRAM
acall command_byte
mov dptr,#fline_data
acall write
ret
; Set DDRAM to the beginning of
; the second line - 40
second_line:
mov p1,#0c0h ;set DDRAM
acall command_byte
mov dptr,#sline_data
acall write
ret
; Feed Command/Data to the LCD module
command_byte:
clr p2.0 ; RS low for a command byte.
jmp bdelay
data_byte:
setb p2.0 ; RS high for a data byte.
nop
bdelay:
clr p2.1 ; R/w low for a write mode
clr p2.2
nop
setb p2.2 ;enable pulse
nop
;******************* Check Busy Flag
mov p1,#0ffh ;configure port1 to input mode
setb p2.1 ;set RW to read
clr p2.0 ;set RS to command
clr p2.2 ;generate enable pulse
nop
setb p2.2
bloop: nop
mov a,p1
anl a,#80h ;check bit#7 busy flag
cjne a,#00h,bloop;keep waiting until busy flag clears
; check busy flag twice
bwait:
mov a,p1
anl a,#80h
cjne a,#00h,bloop
clr p2.1 ;return to write mode
ret
; Data Bytes
FLINE_DATA:
db '>>8051projects<<'
db 099h
SLINE_DATA:
db 00h,01h,02h,03h,04h,05h,06h,07h
db 099h
CGRAM_DATA:
font1: db 0ah,15h,11h,11h,0ah,04h,00h,00h
font2: db 04h,0ah,11h,11h,15h,0ah,00h,00h
font3: db 04h,0eh,15h,04h,04h,04h,04h,00h
font4: db 04h,04h,04h,04h,15h,0eh,04h,00h
font5: db 18h,18h,1fh,1fh,1fh,18h,18h,00h
font6: db 1fh,1fh,03h,03h,03h,1fh,1fh,00h
font7: db 0ah,15h,0ah,15h,0ah,15h,0ah,00h
font8: db 15h,0ah,15h,0ah,15h,0ah,15h,00h
db 99h
end >
thanks
