I'm new with microcontrollers and I have some questions.
I'm using the Aduc842 with a 32.768KHz crystal. I want to use the Analog to Digital Converter and I want to get 8000 samples per second. I'm using timer2 for the interrupt of ADC.
I saw this in an example:
sample period = 2 * T2 reload prd=2*(10000h-FFF4h)*5.722us=2*11*5.722us=125.884us
Where does 5.722us come from? Can you help me to choose the right RCAP2L, RCAP2H, TL2, TH2?
I also want to send via UART some data with 115200 baudrate that I generate with timer3. VDD is 3v, and I read that the maximum coreclock when VDD=3v is 8.38MHz and that CD bits shouldn't be 0.
With this, is it possible to reach 115200 baudrate with a 8.38MHz coreclock? what value should be T3CON and T3FD?
I'm using the Aduc842 with a 32.768KHz crystal. I want to use the Analog to Digital Converter and I want to get 8000 samples per second. I'm using timer2 for the interrupt of ADC. Let me assume it is a 6 clocker and then at 32kHz you get ~5000 instruction cycles (~2000 instructions) executed per second. That makes it darn difficult to get 8000 samples in that time. even if it was a one-clocker (I have heard of no oneclockesr but the SILabs) you would not be able to process a sample in 4 instruction cycles (~2 instructions)
also I also want to send via UART some data with 115200 baudrate that I generate with timer3 put that into the Keil baudrate calculator http://www.keil.com/c51/baudrate.asp together with your clock speed and see.
As stated above, I assume about a chip I do not use, If it has a PLL or some such thing I am totally off the rocker.
I guess you need to clarify some things and a link to the datasheet would be nice.
That chip has an on-chip PLL indeed.
The 5.722us is the Timer2 cycle time.
What the final PLL-output frequency?
how can you tell The 5.722us is the Timer2 cycle time. when you have to ask What the final PLL-output frequency?
Thanks for your answers.
Here you have the datasheet of the microcontroller: www.analog.com/.../ADUC841_842_843.pdf
As the datasheet says:
The ADuC842 and ADuC843 are intended for use with a 32.768 kHz watch crystal. A PLL locks onto a multiple (512) of this to provide a stable 16.78 MHz clock for the system. At 5 V the core clock can be set to a maximum of 16.78 MHz, while at 3 V the maximum core clock setting is 8.38 MHz. The CD bits should not be set to 0 on a 3 V part.
So, in my case (maximum 8,38MHz), PLL control register should be PLLCON=0x001.
And reading the Timer 3 Generated Baud Rates' formulas I find that for 115200 baudrate T3CON=0x082 (DIV=2) and T3FD=0x009.
To control the analog to digital converter I use timer2. I want a 125us sample period. I know timer2 reload period depends on the PLL frequency, but how can I calculate it?
if AD has not 'deviated' T2 will run at SYSCLK/2 so the 'step time for T2 will be 1/SYSCLK ~ 238ns. so you must set RCAP to 65536 - x where x = 125000/238.
please verify
