Dear sir ;
In my project, I want to write some critical data in 512k FLASH of LPC2368.Here I am using In Application Programming for the same.
I refered code from, C:\Keil\ARM\Flash\LPC_IAP2_512 and I am facing a problem while I am writing to FLASH like,
int ProgramPage (unsigned long adr, unsigned long sz, long long int buf[][2]) { n = GetSecNum(adr); // Get Sector Number IAP.cmd = 50; // Prepare Sector for Write IAP.par[0] = n; // Start Sector IAP.par[1] = n; // End Sector IAP_Execute (&IAP); // Execute IAP Command if (IAP.stat) return (1); // Command Failed IAP.cmd = 51; // Copy RAM to Flash IAP.par[0] = adr; // Destination Flash Address IAP.par[1] = (unsigned long)buf;// Source RAM Addres IAP.par[2] = sz; // Fixed Page Size IAP.par[3] = CCLK; // CCLK in kHz IAP_Execute (&IAP); // Execute IAP Command if (IAP.stat) return (1); // Command Failed return (0); // Finished without Errors
This code is working fine if I am passing source address as some array ,which is locally declared in USER RAM. In my application ,I want to write the data present in the 8KB USB SRAM memory to FLASH memory.If I am copying the data from USB memory to USER RAM and then writing this USER RAM data to FLASH memory,it is success.
But if I am passing the USB address (0x7FD00000) as a parameter to ProgramPage() ,then it is returning "IAP.status" as "4" , which means Failure.
In LPC2368 user manual "user.manual.2368.lpc2378.pdf "page number 534 of 614, if I am getting "IAP.status" as "4",it is mentioned as "Source address is not mapped in the memory map.Count value is taken in to consideration where applicable ".
I would like to know whether copying data from USB memory to FLASH memory directly is the correct way or not. If it is correct, How can I map USB source memory(i.e. the 8kB USB SRAM) as mentioned in the above paragraph.
sincerely shamsudheen OP
The only memory remapping I know about is for the interrupt vectors.
So, if the IAP complains about using the USB memory as source, you will have to copy the data to a buffer in the "normal" RAM area.
IAP cannot use USB memory. See Errata LPC23xx.
Suvidh
