hello again,
now I'm able to turn on the leds on my AT91RM9200 board, but I'm not able to work with interrupts - I don't know if the problem is the code or the problem is still in the startup file? Is there a chance to get to know where the problem is?
I work with GNU compiler and that's my code for the interrupt... when I press the Halt button the yellow arrow stands at the position
0x00000018 EAFFFFFE B 0x00000018 (which is the irq-handler in the startup file)
the whole code in my main routine (timer interrupt) is
void ST_interrupt (void)__attribute__ ((interrupt)); void ST_interrupt(void) { AT91C_BASE_PIOC->PIO_OER = AT91C_PIO_PC0 | AT91C_PIO_PC1; AT91C_BASE_PIOC->PIO_PER = AT91C_PIO_PC0 | AT91C_PIO_PC1; xyz->PIOD_PPUDR = AT91C_PIO_PC0 | AT91C_PIO_PC1; AT91C_BASE_AIC->AIC_EOICR = AT91C_BASE_ST->ST_SR; } int main(void) { volatile int period; //config AIC AT91F_AIC_ConfigureIt(AT91C_BASE_AIC, AT91C_ID_SYS, AT91C_AIC_PRIOR_HIGHEST - 6, AT91C_AIC_SRCTYPE_INT_LEVEL_SENSITIVE, (void (*) ())ST_interrupt); period = 10000000; //delay in ms AT91F_ST_SetPeriodInterval(AT91C_BASE_ST, period); AT91F_AIC_EnableIt( AT91C_BASE_AIC, AT91C_ID_SYS); AT91F_ST_EnableIt(AT91C_BASE_ST, AT91C_ST_PITS); while(1); }
I also tested the version with the following:
AT91F_AIC_ConfigureIt(AT91C_BASE_AIC, AT91C_ID_SYS, AT91C_AIC_PRIOR_HIGHEST - 6, AT91C_AIC_SRCTYPE_INT_LEVEL_SENSITIVE, (&ST_interrupt);
But the result is always the same... In another thread I read that I must define the interrupt handler in the startup file, but when I take a look into the interupt example for the gnu compiler which comes with the keil enviroment - there are no changes...
I hope anybody could help me - if the problem could be in the startup file or if the startup file should be ok, when I'm able to turn on leds...
best regards Johannes
could anybody help me with the timer interrupt - I don't know where the error is... the gnu compiler version is 3.22
thanks a lot Johannes
so now I get a data abord error during loading the startup file...
0x00000000 E59FF018 LDR PC, [PC, #0x0018]
But how can I see which instruction in the startup file cause this error?
