Hi everyone. I have the Atmel AT91SAM7X256-EK board, uVision3 and ULINK . I have successfully installed the ULINK on my machine, however, every time I try to program the flash through ULINK, I get the following error: "Error: Flash download failed - Target DLL has been cancelled". When I try to run in debug mode, I get a similar error. I can't seem to figure out what is causing the problem.
Can anyone suggest a solution?
Set the ULINK communication frequency to 100Khz. It is 1Mhz by default.
Regards
Suvidh
Thanks. 100KHz didn't actually work, I had to drop down the speed to 10KHz - but it worked.
Thank you very much.
Vartan
