hi friends,
I am using the AT91SAM7SE512,
i want to measure the external frequency(1KHz) using the Timer/counter. I have connected this frequncy to the PIO pin, The code is if ( (AT91F_PIO_GetInput(AT91C_BASE_PIOB) & Inputpin ) == 0 ) // count pulse {
if(s==1) { AT91C_BASE_TC0->TC_CCR = (AT91C_TC_CLKEN | AT91C_TC_SWTRG ) ; s=0; } } else {
AT91C_BASE_TC0->TC_CCR = (AT91C_TC_CPCDIS|AT91C_TC_CLKDIS ) ; s=1; value = AT91C_BASE_TC0->TC_CV; print(value); delay(50); } By using this code i can able to measure only 10Hz. But i want to measure up to 5KHz. can you please tell me the procedure to intialise the Timer/counter.
with regards, Murthy.R
www.danlhenry.com/.../keil_code.png
My code is
if ( (AT91F_PIO_GetInput(AT91C_BASE_PIOB) & Inputpin ) == 0 ) // count pulse { if(s==1) { AT91C_BASE_TC0->TC_CCR = (AT91C_TC_CLKEN | AT91C_TC_SWTRG ) ; s=0; } } else { AT91C_BASE_TC0->TC_CCR = (AT91C_TC_CPCDIS|AT91C_TC_CLKDIS ) ; s=1; value = AT91C_BASE_TC0->TC_CV; print(value); delay(50); }
with regards Murthy.
You should first try to reformat your source code to improve the readability. As a result you make it easier to understand the code and to find errors for other and you.
en.wikipedia.org/.../Programming_style
Kind regards,
Rainer
hi friend , thanks for your suggestion, Here is the code
if((AT91F_PIO_GetInput(AT91C_BASE_PIOB)&Inputpin )==0) { if(s==1) { AT91C_BASE_TC0->TC_CCR=(AT91C_TC_CLKEN|AT91C_TC_SWTRG); s=0; } } else { AT91C_BASE_TC0->TC_CCR=(AT91C_TC_CPCDIS|AT91C_TC_CLKDIS ) ; s=1; value = AT91C_BASE_TC0->TC_CV; print(value); delay(50); }
