Dear All The computer output 8 bits data of P1.24~P1.31, and I save the data on the buffer(EPP_Data); then the data was input to LCD driver IC via the P0.0~P0.7.
Problem: My computer output 0x11 via P1.24~P1.31 and use scope to check computer output data is correctly show 0x11, but the data (0x11) via P0.0~P0.7 into LCD driver IC, the data somehow becomes inaccurate(and it shows 0x61). I wrote my program as follows,and I wonder if any mistake?
//Pin Define// #define CS P1_16 #define WR P1_17 #define RD P1_18 #define RS P1_19
#define EPP_WR P1_20 #define EPP_AS P1_21 #define EPP_DS P1_22 #define EPP_WAIT P1_23
#define EPP_Data0 P1_24 #define EPP_Data1 P1_25 #define EPP_Data2 P1_26 #define EPP_Data3 P1_27 #define EPP_Data4 P1_28 #define EPP_Data5 P1_29 #define EPP_Data6 P1_30 #define EPP_Data7 P1_31
void main(void) { uint32 EPP_Data;
PINSEL0 = 0x00000000; PINSEL1 = 0x00000000; PINSEL2 = 0x00000000;
IO0DIR = 0xFFFFFFFF; IO1DIR = 0x008FFFFF;
while(1) { IO1CLR = EPP_WAIT; if((IO1PIN & EPP_WR ) == 0) { if((IO1PIN & EPP_AS) == 0) { EPP_Data = IO1PIN & 0xFF000000; EPP_Data = (EPP_Data >> 24);
IO0CLR = 0x000000FF; IO1CLR = CS; IO1CLR = RS; IO1SET = RD; IO1CLR = WR; IO0SET = EPP_Data; IO1SET = WR; IO1SET = CS; IO1SET = EPP_WAIT; } } } }
on P0.0 - P0.7 there are some I2C pins which do not have an on-chip pull up. You need pull-up resistors on those pins. Did you add them?
