Hello word
I'm trying to download my software onto MCB2300 board with the last release (3.65) of flash magic tools and but i have no synchronization with the board (first spep? synchronized). I check configuration board with the last documentation. if I'm trying to initiate the communication with terminal, i've obtained same result : no synchronization !
All it's working if I change MBC2300 board by an another based on LPC2292 chip
Somebody could help me
Thanks for all:
http://www.flashmagictool.com/ ?
I already used Flash Magic(3.58.226) with the MCB2300 board(Vers.3) and it worked great.
Maybe you set the some wrong configuration options? So here are the ones I used successfully: Baudrate: 57600 Device: LPC2378 Interface: None(ISP) Oscillator Freq: 12.000000
Be sure to use the correct COM 0 port on the board.
That's all I can say...
Hello Stephen,
please take a look at www.keil.com/.../mcb2300_fp_flash_utility.htm
Best Regards, Martin
