P89V51RD2 - IAP can't do it..
I am trying to work with the IAP for P89V51RD2.
I just tried to check the following code which I expect to
program the memory location 0x0020 with 01h.
I am using a clock=40 Mhz and am stroring that value in R0. But the code is not working. ie when I try to read memory from Flash Magic, I do not see any change at 0x0020
Can anyone fix the problem??
code is:
        ORG 00
                        MOV   DPH,#00h
                        MOV   DPL,#20h
                        MOV   A,#1h
                        MOV   R0,#40
                        MOV   R1,#02H
                        CALL  0FFF0H
                        END
  • I am using a clock=40 Mhz and am stroring that value in R0. But the code is not working. ie when I try to read memory from Flash Magic, I do not see any change at 0x0020
    that will not work, unless the chip is in 12 clock mode. Are you sure it is
  • You might want to take a GOOD look at the data sheet. The API call is NOT compatible with the V51 chip.
    This chip uses a special memory page for the IAP code and whose entry point is address 0x1ff0.
  • No guys.. I got it working..
    It is surely not the case that frq should be 12MHz neither is it necessary to have C51 chip..
    The code is
     org 02100h
             PUSH    IE          ;DISABLE INTERRUPTS
             CLR     EA
                     MOV     A, 0B1h
             ANL     A,#0FCh   ;enable boot sector - !!! this command MUST be located ABOVE 2000h!!!
             MOV     0B1h, A
                     MOV   A,#1h
                     CALL    01FF0H      ;call to ISP_API (modifies B register but no Rx)
                     MOV   DPH,#00h
             MOV   DPL,#00h
                            MOV   R1,#02H        ; function code
                     MOV     A, 0B1h
                     ORL     A,#001h   ;switch back to user FLASH
                     MOV     0B1h, A
             POP     IE
    END
