Can any one help me plz This is the code for some delay on p1.0 pin
org 0000h mov tmod,#01h back: mov th0,#0f0h mov tl0,#0f0h setb tr0 cpl p1.0 here: jnb tf0,here clr tr0 clr tf0 jmp back end
My problem is value in TL is not incrementing properly .TL is displaying only even numbers . TF is setting when ever T0 reg is becoming 0000 and port bit is also working properly. TL value incrementing even TR0 falg is 0 again reloading with T0 value when TR0 is 1. And finally iam not getting the result when I loaded this code into controller.
all instructions are 2-cycle instructions. That is the reason whey TL is incremented in steps of 2.
Which result are you expecting. The program really does not make any sense.
help me plz sounds like a prostate problem, go see a doctor.
on your code TL is displaying only even numbers . most likely due to the synchornization between the timer clock and the uC instruction cycle. You can write code that in the ICE only show numbers divisible by e.g. 7 on a given breakpoint.
If you are using a simulator do you not understand the meaning of the word "simulate"
thats not what my girlfriend said to me last night!
