Problem using "#pragma small" and the volatile dilemna
Hello gurus!
I am developing code for an 8051 variant with 2K of on-chip XDATA and 32K of flash.
Question 1:
I have compiled the entire project with memory model as "large". I am trying to see the effect of using "small" memory model for a specific file. What I have learned from Keil's help is, and I quote "These directives apply to the entire source file and may be specified only once on the command line or at the beginning of the source file using the #pragma statement. They may not be used more than once in a source file. "
I am trying to use #pragma small at the top of my C file, but it gives the error:
ACTION: PARSING INVOKE-/#PRAGMA-LINE LINE: #pragma SMALL ERROR: RESPECIFIED OR CONFLICTING CONTROL
I have even tried specifying "small" in the individual options for the file (under C51 tab), but to no avail. What is my mistake ? What is the correct method ?
Question 2:
I have about 1.9KB of variables in XDATA, which have been declared as "volatile unsigned char xdata bla_bla;". In order to use them in other files, their respective "extern" declarations are written in a header file and included in all C files, e.g.:
"extern volatile unsigned char xdata bla_bla;"
Is there a need to specify "volatile" keyword in the extern declaration as well ? If I remove the "volatile" keyword from the "extern" declaration, I save about 400 bytes of source code. When "volatile" has been specified as part of the actual definition, why does "volatile" in extern affect the code size ?
Hoping a quick response from all the gurus....
Regards
Aman
  • Question 2:
    Yes, you need to specify "volatile" in the declaration in the header. This is the only way other modules know that the variable should be treated as volatile. If the header does not so inform them, then when code is generated for those other modules, it will not treat the variable as volatile. (Although Keil does do some whole-program analysis, C is traditionally a "separately compiled" language; one .c file doesn't really know what's going on inside another.)
    The main effect of declaring a variable "volatile" is on the optimizer.
    "Volatile" tells the compiler that it cannot safely assume that the value of the variable does not change when the current code isn't reading or writing it. That is, the variable may represent a register where the hardware changes the value, it may represent an address where the actual read/write bus cycles are important to trigger activity and thus all of which must appear on the bus. Or it may be that an interrupt handler or another task shares the value and can change the variable by interrupting the current function.
    In short, "volatile" forces the compiler always to write back to the variable or read from it, rather than using common optimizations such as realizing that the value is already in a register, and using that value instead of the actual variable.
    Given that, it's easy to see why changing the declarations as "volatile" affects the code size. The compiler has to generate more reads and writes to volatile variables than normal ones.
  • [...] I have even tried specifying "small" in the individual options for the file (under C51 tab), but to no avail. What is my mistake ? What is the correct method ?
    #pragma small is not really meant to be used in conjunction with the IDE --- it's for users who don't use the IDE, and prefer to store option settings inside the source instead. As one consequence once you specified LARGE in the project-wide option settings, the IDE doesn't offer any way to turn it off for individual files. Your only option is to leave the project option at its default (SMALL), and then explicitly add LARGE for those files that should have it --- the opposite of what you've been trying so far.
    On the other hand, studying the effect of small model based on entire source files doesn't make terribly much sense anyway. It's probably better to experiment with individual functions and variables instead.
  • and then explicitly add LARGE for those files that should have it
    a much better idea: "and then explicitly add xdata for those variables that should have it".
    for instance a process like
    for (index = 0; index < 333; index++)
    { ... xdata = ....
    will run a whole lot faster than
    model LARGE
    because 'index' stay in DATA in the first example
  • Thanks for the advice Erik.
    BTW, won't the IDE give me the same problem if I select "small" as the memory model and try to give "large" for a specific file ?
    Regards
    Aman
  • Since this is on-chip xdata, do you really even need the "volatile" keyword? The only reason I can thing of would be if an interrupt routine accessed the 'xdata'.
    Does your interrupt routine need access to all the bytes in xdata?
  • Hi All,
    What is the meaning of "You may, however, specify which memory model to use for a single function by
    including the small, compact, or large function attribute in the function
    declaration." (extracted from the C51.pdf by Keil)
    Question regarding #pragma regparms:
    I have one more question regarding the large memory model. When the large model is selected, then by default all function parameters are passed on XDATA. Is it that if I have the large memory model selected, I cannot use "#pragma regparms" to pass parameters in registers for a particular function ? I am somehow unable to do it. I encapsulated my function like this:
    #pragma save
    #pragma regparms
    void foo (unsigned char var)
    { bla bla
    } #pragma restore
    However, when I check the map file, the location of variable has not changed, it is still passing on xdata. Where am I wrong ?
    Question regarding overlaying:
    "The total stack space of the classic 8051 is limited: only 256 bytes maximum.
    Rather than consume stack space with function parameters or arguments, The
    Cx51 compiler assigns a fixed memory location for each function parameter.
    When a function is called, the caller must copy the arguments into the assigned
    memory locations before transferring control to the desired function."
    Now, the question is, is there any linker option where same memory location (in XDATA or IDATA) can be used for passing parameters to two or more functions IF I am sure that they can NEVER be called at the same time (through ISR or whatever) and the MCU does have an OS running on it ?
  • Actually some of the variables are accessed through ISR as well, but I am planning to removed the volatile keyword from others.
    Thanks for the advice.
  • One problem has been solved. I had been using "small" model for many functions, but just could not see it. Its easy:
    void foo (unsigned char) small;
    This is what I was looking for, i.e. small model function in a large model project
    Regards
    Aman
  • Overlaying problem also solved. Linker has now started to overlay variables in DATA. I did not do anything except that I used "small" with some functions. For some functions it did by itself.
    Only REGPARMS mystery remains to be solved
    Regards
    Aman
