Any one know the solution, please reply.
After declaration,
FILE *fin;
and implementation,
fin = fopen ("test.txt","r");
The error message results when compiling:
Build target 'ADuC7020' assembling Startup.s... compiling ADC.c... ADC.C(30):error C67:'FILE': undefined identifier ADC.C(31):error C67:'fin': undefined identifier
I already include the header file 'rtl.h' in my program.
Do you have a library with a flash file system implementation?
File functions are not part of the standard compiler packages for embedded development.
Thanks much your reply.
All I have is the evaluation version Keil uVision3 from CD-ROM.
I understand your point having read on this page,
http://www.keil.com/rl-arm/
at the bottom 'Note Box',
'The RealView MDK-ARM includes the RTX Real-Time Kernel but not the RTX Real-Time Kernel Source Code, Flash File System, TCP/IP Protocol Suite, or USB/CAN Drivers.'
Is this meaning that those programs in folder C:\Keil\ARM\RV30\RTL\Kernel\Examples\ cannot be run ?
But there are some source codes in path C:\Keil\ARM\RV30\RTL\Kernel\Examples\SRC\ ?
Hope you reply
Examples that only makes use of the RTX real-time kernel should be possible to build. It's only the kernel source that isn't available.
You will not be able to build projects making use of flash file systems, TCP/IP or CAN. Any pre-built applications with these features should be possible to run.
Correct.Thanks much.
