Hi. I tried to use the Signal Function i my project (lpc2129) and it didn't work. There an error appeared during compilation. Code of my simple signal function:
void signal sig(void) { ain1=1.0; twatch(100); }
Can someone explain why it doesn't work?
"an error appeared during compilation."
Do you not think that it might be helpful to quote exactly what error it was that appeared?
error: #70: incomplete type is not allowed error: #65: expected a ";"
wrong syntax - it should be something like shown below. You might also look into the 'Measure' example provided with the MDK.
Signal void analog0 (float limit) { float volts; printf ("Analog0 (%f) entered.\n", limit); while (1) { /* forever */ volts = 0; while (volts <= limit) { ain0 = volts; /* analog input-0 */ swatch (0.01); /* wait 0.01 seconds */ volts += 0.1; /* increase voltage */ } volts = limit; while (volts >= 0.0) { ain0 = volts; swatch (0.01); /* wait 0.01 seconds */ volts -= 0.1; /* decrease voltage */ } } }
The code shown above doesn't work. Another error appeared: error: #77-D: this declaration has no storage class or type specifier
I had been trying to use signal functions presented in Keil user's guide...and nothing...
The signal function shown before applies to the uVision simulator and acts much like a script which generates inputs to the simulation. Such funtions are 'compiled' in the simulator environment by a built in parser and.
Trying to compile a 'signal' funtions with the MDK/RVCT compiler makes no sense since it does not know anything about the simulation or 'signal' or 'twatch' etc.
