MCBSTR9 ethernet maximum throughput at 96MHz
I am using MCBSTR9 evaluation boards for testing the ethernet throughput (sending 1316 bytes length UDP packets).
I have implemented my code using the Keil HTTP demo with RTX_Kernel and running the board at 96MHz.
The maximum speed I got is (aprox) 40Mbit/s but I have two questions:
1. Is it possible to set FMICLK = RCLK = 96Mhz (now is RCLK/2) ?? (PLL config (2,192,25), Or there is any kind of speed limitation??
2. Is there any other TCP/IP stack optimized for this board to get a higher throughput??
thanks,
Firin
  • There are other settings you can optimize:
    1. enable PFQBC unit (STR91x.s)
       System Configuration - SCU_SCR0 - EN_PFQBC
    2. disable DTCM wait state (STR91x.s)
       System Configuration - SCU_SCR0 - WSR_DTCM
    3. disable AHB wait state (STR91x.s)
       System Configuration - SCU0_SCR0 - WSR_AHB
    4. set FMI wait states to 1 Wait State
       Flash memory Interface - WSTATES
    With those changes you will have much better benchmark results.
    You can set FMICLK = RCLK = 96Mhz for new STR912FA devices not for STR912F.
    Franc
  • Thank you very much Franc.
    I have changed all these settings and the performance is much better, specially enabling the pre-fetch QBC unit.
    Regards,
    Firin
