Sttings for
Hi. Where can I find the correct settings for aplications using Phytec KC-161 eval board? Because the arrays are not initialized when the device is running without debug. I'm a biginer and i tryed the following simple code at blinky project from \Boards directory, and the result in Hyper Terminal is not I expect. Thank you.
#include <reg161.h>
#include <stdio.h>
#include <string.h>
void setup_serial();
void main (void)  {
        unsigned int vector[6];
        unsigned int cnt;
        setup_serial();
        for(cnt=0; cnt<6; cnt++){
                vector[cnt] = 1;
                if(vector[cnt] != 1)
                        putchar('!');
                else
                        putchar('1');
//in hyper terminal is displaying six of '!', WHY?
//it must be six of '1'!
        while (1) {
void setup_serial(){
  /* init physical memory model */
  BUSCON0 |= 0x003F;    /*; 0 Wait no Delay */
  /* initialize the serial interface     */
  P3  |= 0x0400;        /* SET PORT 3.10 OUTPUT LATCH (TXD)              */
  DP3 |= 0x0400;        /* SET PORT 3.10 DIRECTION CONTROL (TXD OUTPUT)  */
  DP3 &= 0xF7FF;        /* RESET PORT 3.11 DIRECTION CONTROL (RXD INPUT) */
  S0TIC = 0x80;         /* SET TRANSMIT INTERRUPT FLAG                   */
  S0RIC = 0x00;         /* DELETE RECEIVE INTERRUPT FLAG                 */
  S0BG  = 0x19;                 /* SET BAUDRATE TO 19200 BAUD AT 16MHZ           */
  S0CON = 0x8011;       /* SET SERIAL MODE                               */
