Bug in uVision 3.51 Debugger (RVMDK 3.05)
When I click debug button, after loading code, show failure message in command window:
JTAG Communication Failure
Then press F11 to run program, it appends "JTAG Communication Failure" in command window.
Stop debugger, and click debug button again, show error in message box:
Error: Could not load file ' xxx.axf'
Debugger Aborted!
Edit xxx.opt file using notepad, remove following line: OPTMM 1,8,(s[2])
Then restart uVision, the problem was resolved.
