Problem to Flash a Hex-File into the KitCon-163 with Phytec 16W Flashtool
Hello
I compile and link my sources without any Problems (Error) then I start my KitCON-163, activated the
Bootstrap-loader and Connected to the device.
After this I try to load the Hex-File for downloading but I can't read the file -> Error message " A Error occured while opening the file ! "
What can I do????????
Daniel
  • I compile and link my sources without any Problems (Error) then I start my KitCON-163, activated the
    Seems like the download tool can't find your Hex-file/application.
    How do you build the app, and download it to the device? Using uVision? Or does the KitCON-163 come with custom tools?
    Regards,
    Joost Leeuwesteijn
  • Dear Joost
    I use µvision2 and generate the h86 file after this I try to open this file with the 16W Flashtool from Phytec -> Only with this Flashtool I got access to the Kitcon board, FlashTool3 and the old FlashT didn't work.
    Best regards
    Daniel
  • I use µvision2 and generate the h86 file after this I try to open this file with the 16W Flashtool from Phytec -> Only with this Flashtool I got access to the Kitcon board, FlashTool3 and the old FlashT didn't work.
    I don't know the 16W flashtool (do you have a link?). And our product uses a custom made tool for the bootstrap download. So I'm affraid I can't help you.
    I suggest contacting Phytec or look to a support forum there. Did you manage to get anything working using the Flashtool? Example projects or something?
    The error message suggest a simple file-not-found or perhaps an incorrect format? The latter can be checked by building an example project.
    Good luck,
    Joost Leeuwesteijn
  • Thanks for your help I will ask Phytec.
    by the way, unfortunately there is no demo project for µv2 available for the Phytec kitcon-C163 demo board that I can compile and test afterwards
    BR
    Daniel
