Hi, following code starts the timer (checked with debugger TIM0->CNTR) but does not lead to an interrupt; using STR711FR2, Keil uVision, ULink2, 16MHz external Clock
RCCU_MCLKConfig(RCCU_DEFAULT); RCCU_FCLKConfig(RCCU_RCLK_2); RCCU_PCLKConfig(RCCU_RCLK_8); RCCU_PLL1Config(RCCU_PLL1_Mul_24, RCCU_Div_4); RCCU_Div2Config(ENABLE); while (RCCU_FlagStatus(RCCU_PLL1_LOCK) == RESET); RCCU_RCLKSourceConfig(RCCU_PLL1_Output);
/* timer initialization */
/* initialize the TIM0 peripheral */ TIM_Init(TIM0); /* set internal clock source */ //TIM_ClockSourceConfig(TIM0, TIM_INTERNAL); /* set prescaler value */ TIM_PrescalerConfig(TIM0, PRESCALER_100_MS); /* enable the timer overflow, interupt */ TIM_ITConfig(TIM0, TIM_TO_IT, ENABLE);
/* Timer 0 */ /* configure IRQ interruptswith EIC */ /* enable channel */ EIC_IRQChannelConfig(T0TIMI_IRQChannel, ENABLE); /* set priority for channel */ EIC_IRQChannelPriorityConfig(T0TIMI_IRQChannel , 1); /* enable interrupts */ EIC_IRQConfig(ENABLE);
expected ISR void T0TIMI_IRQHandler(void) {...}
Thanks werner
