Hi!,
Two questions about memory allocation:
1.- How can I locate this expression in ROM Flash?:
char AUTOTEST [20+1]="=====SELFTESTING====";
There are any '_rom' tense?
2.- How can I locate a block of global variables on an specific address?
If I declare on 'VARIA.C': unsigned char Log_On_OK[MAX_OK];
And this variable is used on 'LOGGER.C', on the '.map' archive berofe compiling, I see: ----------------------------------------------------- logger.o(.data)
Log_On_OK 0x00000024 Data 12320 ------------------------------------------------------ But I want to locate Log_On_OK where I want and that the compiler knows it, and asociate 'Log_On_OK' with 'varia.o'
Thanks!!!
1.- ¿posible 'const'?
