I had purchased C8051F330 Development Kit and having some problems.
I can download and debug the code from Silicon Laboratories IDE. and also via Flash Programming Tool Provided. But Can Not Do it through Keil uVision2. It gives an error stating "Target Failed To Respond. System Is Being Disconnected". Is There anything missing. I had installed uvision debug driver and having C8051Fxxx in Flash Downloader List
You should be sure set your debugger correctly.As I know,there are two kinds of SiliconLab jtag debugger,one uses 232 serial while the other use USB interfact to communicate with a PC.
So,if you leave the debugger option default to a serial interface while usiing a USB one,the target will sure not respond.
There was no Option of Port in Flash Download Utility Option. But It was in Debug Tab. I set it to COM5 (Its a Virtual Com Port Made By U-EC2 Debug Adapter), and all of the issues were resolved
All programs for ISP I know of (FlashMagic, SILabs, Atmel) have problems with most USB to serial converters. At the FlashMagic forum there is an attempt to sort out which work and which do not for FM and I believe that those that work for FM will also work for SILabs. It seems that the chip inside is the determining factor.
If you believe that any USB to serial adapter does the job correctly, I have some Swampland in Florids to sell.
It seems that the chip inside is the determining factor. It seems that the chip inside the USB to serial converter is the determining factor.
A Dane correcting his own English, eh...? ;-)
