I have MCB2130 with LPC2138 onboard. I added some .c files in standard "Hello" example, wich is provided with uVision v3.
Problem: When I try to download my Hello.afx to the board the window appears:
Error: Flash Download failed - ARM7TDMI
In the Build window I have the following: linking... ".\Obj\Hello.axf" - 0 Error(s), 0 Warning(s). Load "D:\\Keil\\Temp\\Obj\\Hello.AXF" Erase Done. Programming Failed!
Would you give me a solution of this problem? Thanks in advance.
Sincerely, Sergey
It's all right. I've found the couse. It's necessary to change "Use Target Driver for Flash Programming"->Settings to LPC2000 IAP2 512Kb Flash.
Please, try to change your settings for Target Driver for Flash Programming Choice programming algorithm LPC2000 IAP 512kB Flash (of course if you Flash can eat it:))
