Hi, i'm kinda new to this so you'll have to excuse my ignorance. I'm using the MC AT89C4051 and I need to program it, so I got the at89x051.h and when I compile my program (with the #include<at89x51.h> ofcourse) with Microsoft Visual C++, I get the following errors:
error C2146: syntax error : missing ';' before identifier 'SP' error C2501: 'sfr' : missing storage-class or type specifiers fatal error C1004: unexpected end of file found
And here is where I got the header file from: www.mcuok.com/.../AT89x051.H
Any help would be greatly appreciated. Thanks in adavance, Alex.
HUH?
Microsoft Visual C++, for the '51??? in a Keil forum???
Hmm.. sorry if I've done something wrong. Just used google and found this forum. I apologize if I've caused any inconvenience.
You haven't, please excuse the ignorant response you received from the other poster. Unfortunately there are a couple of contributors around here who derive their amusement from trying to ridicule newcomers.
If I understand you correctly you are trying to compile a 'C' program using VC++ to run on an Atmel 8051 derivative. You can't do this - you need to use a cross compiler such as Keil C51 that generates 8051 code rather than x86 code.
Thank you for the reply :) I suspected that was the cause for the errors. I have another software called Raisonance Kit - RIDE that works together with CEIBO EB-51. Maybe it's compiler is good? Or keil is the only option?
Thanks again for the reply :)
Keil is the best, but not the only, option. Raisonance, for all pracical purposes, is a Keil clone.
using Raisonance, the help is found at www.raisonance.com/.../list.php
And then there are those like Jack that "derive their amusement" from criticising every response that is not exactly to their liking.
No. I get my fun from correcting your false statements.
and when there is nothing false, you "get your fun" from labelling a correct but brief post 'ridicule'. Well I am getting used to the fact that whatever I post you will find a way to make a non-technical personal attack. Be advised my skin is thick. Ooes that maen that I will let a non-techinical personal attack stand, of course not.
Ok, let's take a look at that post:
It is certainly brief, but there's nothing in it that could be described as 'correct'. It's just a deliberately unhelpful and rude response. Take a look at your use of capitalisation and multiple question marks.
Here, let me try replying to your post using your style:
Couldn't you understand the OP's question??? HUH???
The correct response would be, then:
Before posting in any new forum (especially one you "just found" with Google), please take care to read the forum's "terms of reference" (or whatever) and ensure that your post is on-topic:
http://www.keil.com/forum/
It says, "The Keil Discussion Forum is an open forum where you may post questions and comments about Keil products" (my emphasis).
Neither MSVC nor Raisonance is a Keil product!
and the cited header file istelf does say "Keil"
"And here is where I got the header file from: www.mcuok.com/.../AT89x051.H "
Hmmm... what are you doing downloading it from there?
Keil publish their header files, and you can download them direct from Keil for free. The genuine Keil page for the AT89C4051 is here:
http://www.keil.com/dd/chip/3030.htm
You can also download the Evaluation version of the Keil tools for free:
www.keil.com/.../c51.htm
Thank you very much. :)
