Hi, i am working on CY7C68013 chip.I am trying to implement SPI using mode0.1Mhz clock is generating,but data is not generating.(CLOCKOUT=24Mhz.I used SM2=0 i.e 24 mhz/12Mhz)I have to get 2 Mhz clock .Below i have attached piece of code which i tried.
main() {
PORTECFG=0x08; //Turn on uart pin rxd0out SCON0 = 0x13; //Mode 0, baud 24/12, enable receive,TI=1;RI=1; // CKCON &= 0xF8; //Set stretch 0*/
while(1) { TI = FALSE; SBUF0='B';//spi_Data; // for(i=0;i<1000;i++); while(!TI); }
please help me to solve this issue.
Regards, smitha
Please see the instructions for how to post legible code:
http://www.keil.com/forum/tips.asp
Note that this information was clearly provided when you made your post - both on the initial form, and in the preview - it's right there between the 'Summary' box and the 'Message' box. It always makes sense to read the instructions first!
main() { PORTECFG=0x08; //Turn on uart pin rxd0out SCON0 = 0x13; //Mode 0, baud 24/12, enable receive,TI=1;RI=1; // CKCON &= 0xF8; //Set stretch 0*/ while(1) { TI = FALSE; SBUF0='B';//spi_Data; // for(i=0;i<1000;i++); while(!TI); } }
please help me to solve this issue. Regards, smitha
please help me to solve the issue
