This code fragment is never reached on the MCB2300 board:
UARTInit(9600); /* baud rate setting */ charToSend = 0x55; for ( ;; ) { charToSend = 0x55; UARTSend( (BYTE *)&charToSend, 1 ); #if 0 charToSend = '1'; UARTSend( (BYTE *)&charToSend, 1 ); #endif for (j = 0; j < 100000; j++) ; }
It works fine by removing either: 1) first charToSend line 2) #if 0 and #endif lines E.g.,
UARTInit(9600); /* baud rate setting */ for ( ;; ) { charToSend = 0x55; UARTSend( (BYTE *)&charToSend, 1 ); #if 0 charToSend = '1'; UARTSend( (BYTE *)&charToSend, 1 ); #endif for (j = 0; j < 100000; j++) ; }
or....
UARTInit(9600); /* baud rate setting */ charToSend = 0x55; for ( ;; ) { charToSend = 0x55; UARTSend( (BYTE *)&charToSend, 1 ); charToSend = '1'; UARTSend( (BYTE *)&charToSend, 1 ); for (j = 0; j < 100000; j++) ; }
Have you looked at the generated code to see what's happening?
Jon
