C51: SPI isn't latching in any data
Hello everyone,
I am currently working on a project which involves communication between an Infineon XC888 with a TI ADS1256 (ADC) using an SPI Interface.
I can successfully send commands to the ADC, but reading the data send back to me is not working at all.
For example:
 SSC_vSendData(0x14); // send the Read Registry command
 SSC_vSendData(0x00); // send # of bytes to be read (1+0x00)
 SSC_vSendData(0x00); // send Dummy Byte
 SSC_Data = SSC_RBL;  // storing of the received data
When I look at the scope, the returned signal on the DOut line looks perfectly fine, but when I read the Receive Buffer (SSC_RBL), it's always empty (0x00).
I also can't image having any timing problems, after all, the Microcontroller should always leave the data in the SSC_RBL register until new data is being send, right?.
Thanks in advance.
PS: SSC_vSendData() puts the byte in the SSC_TBL register and waits until the Busy flag is cleared.
  • Okay, I found my problem.
    Due to a fault with a voltage regulator, was the Digital VDD of the ADC too low (instead of 3.3V).
    This resulted in an SPI signal that was not compatible with the µC.
    Live and learn...
