Hallo! I'm searching for a explanation for the code in Keil's CAN.h (01=set; 10=reset) <-------------code-------------> ... #define NEWDAT_ 0x0200u #define CPUUPD_ 0x0800u #define TXRQ_ 0x2000u ... #define NEWDAT_CLR (~NEWDAT_) #define CPUUPD_CLR (~CPUUPD_) #define TXRQ_CLR (~TXRQ_) ... #define NEWDAT_SET (~(NEWDAT_ >> 1)) #define CPUUPD_SET (~(CPUUPD_ >> 1)) #define TXRQ_SET (~(TXRQ_ >> 1)) ... For example, this statement clears (resets) the CPUUPD flag and sets the NEWDAT and TXRQ flags, while leaving all the other flags unchanged: CAN_MSGOBJ[can_object_number].msg_ctl = CPUUPD_CLR & NEWDAT_SET & TXRQ_SET; ... <-------------/code-------------> (How) does it work (leaving all the other flags unchanged)? Has it something to do with the u or what does the u stand for? I know bit manipulation/masking in the way bitfield = bitfield | (0x2); //set bitfield[1] bitfield = bitfield & ~(0x2); //clr bitfield[1] Thanks Sven.
Ok, you didn't say what device you are using. For example if you are referring to an Infineon device then you have two bits to control the field as you stated but you missed that 11b means leave the element unchanged. The u is for the compiler to treat the value as unsigned.
Ok, you didn't say what device you are using why would he, it is much more fun to have us guessing. Erik
Sorry for that, i thought it is a more general matter - i use a ST10F269. I did not recognize that the function of "11" on write is to leave element unchanged (which is in my case). It's now clear to me. Thanks for the hint and explanation of u.
