Hi I am trying to store data into the EEPROM . I used the sample code available in this website. But the code does not work .Can anyone find out the mistake here . Please give me a sample working code. I am using 89LPC931 running at 11.059Mhz. Thanks #include <reg31.h> #include <stdio.h> void EEPROMwrite(unsigned int adr, unsigned char dat); unsigned char EEPROMread(unsigned int adr); unsigned char redat,pus = 0x34; unsigned int ADR =0x82; void main(void) { EEPROMwrite(ADDR, pus); redat=EEPROMread(ADDR); while(1) { } } void EEPROMwrite(unsigned int adr, unsigned char dat) { EA=0; // disable Interrupts during write DEECON=(unsigned char)((adr>>8)&0x01); // mode: write byte, set address DEEDAT=dat; // set write data DEEADR=(unsigned char) adr; // start write EA=1; while((DEECON&0x80)==0); // wait until write is complete } unsigned char EEPROMread(unsigned int adr) { DEECON=(unsigned char)((adr>>8)&0x01); // mode: read byte, set adress DEEADR=(unsigned char) adr; // start read while((DEECON&0x80)==0); // wait until read is complete return DEEDAT; // return data }
Accessing Data RAM in P89LPC931 I am trying to store data into the EEPROM either the title of the post is wrong or you are totally confused
I am sorry . I want to access the RAM. I made a mistake of accessing EEPROM(it does even have an EEPROM).Can anyone give me some sample code for accessing RAM.
RAM is 3 things DATA IDATA XDATA which?
I need to access the DATA and IDATA .
i do not understand your question, if you do NOTHING WHATSOEVER, but have any variable, you will be accessing DATA Erik
http://www.keil.com/support/man/docs/c51/c51_le_memareas.htm http://www.keil.com/support/man/docs/c51/c51_le_data.htm http://www.keil.com/support/man/docs/c51/c51_le_idata.htm
