I am using an EPM900 to emulate the P89LPC933 from philips. I do not manage to configure the A/D converter available in the micro and get it to work. Need to perform a single conversion on the AD10 pin (P0.1). Do you have any sample code in assembler
Do you have any sample code in assembler Why not show your code? Erik
Here goes this part of the code MOV P0M1,#10001110B MOV P0M2,#01110000B MOV PT0AD,#00000010B MOV ADMODB,#000H ; This dam thing does not leave MOV ADINS,#0x010 ; me alone MOV ADMODA,#0x010 MOV ADCON1,#0x05 ; Go to work
This dam thing does not leave A language problem, I'm sure, please explain. Are you saying that the uC stop on that instruction? Erik
When i execute the above lines the SFR's do not assume the new value.
show it all. some LPC pins can not be modified if bthey are assigned as certain things (e.g. enable IIC and the pins can only be set OC) also, before selecting analog pins on P1 you should configure P1M1 and P1M2 Erik
I am using port o, as you can see on the code. I use P0.1 as input pin for the A/D to perform a single conversion. I am using the pin to read the battery voltage of the equipment. Why don't the control registers assume the configuration values?
Why don't the control registers assume the configuration values? as stated before, the SFRsa will only accept "legal" values. Have a look at what you set and what you get and check that in the user guide. If that does not clear it up in half an hour, post what you set and what you get. Erik
The values remain at 0
The values WHAT values? Erik
The SFR values. When i perform the mov instruction, the rigister does not assume the new configuration value.
well one step at the time mov a,#47 if the emulator show acc to be 47, so far, so good MOV P0M1,#10001110B mov a,P0M1 what does a show what does p0m1 show
When i perform the following instructions the ADINS does not assume the new value MOV A,#0x010 MOV ADINS,A
I am trying to help you, DO WHAT I ASKED, not something else Erik
Thanks. That works fine.
What next
