HELP!! how to use PEC to send data to serial interface(TXD)
The Code runs in XC164CM(C166 core)
The following program shows how to program PEC channel 0 for data transfers to the serial port transmit buffer, but I can't see anything from TXD. Whether somebody knows how to resolve it?
//========== main.c ======================
#include<reg166.h>
#include<INTRINS.H>
#pragma PECDEF (0)
const char string[] = "0123456789\n";
void serial_PEC0_setup(void)
PECC0 = 0x0500 |
((sizeof(string)/sizeof(string[0])) - 1 );
SRCP0 =_sof_(string);
DSTP0 =(unsigned int) &S0TBUF;
void Tx_IRQ(void) interrupt S0TINT = 42
serial_PEC0_setup();
void serial_setup(unsigned int baurate)
S0BG =(16000000UL/(32UL*(unsigned long)
baurate)) - 1;
DP3 |= 0x0400;
DP3 &= ~0x0800;
P3 |= 0x0400;
S0CON = 0x8011; // 8, N, 1
S0TIC = 0x00F8;
IEN = 1;
void main(void)
serial_setup(19200);
while(1);
