I am using the XBYTE macro to access a memory mapped device. The chip select is being handled via another port (P1) to allow the full 64K of addresses to be axcessed. When I read data from the memory device I read 0x00 from addresses 0x00 - 0xFF. Above 0xFF the data reads correctly. I have verified that the memory device contains valid data in 0x00 - 0xFF address range. I also have scoped the RD line and it does appear that it is activated to read the data. Please let me know any thoughts. Thanks.
which chip? I know of chips with internal external memory (EDATA), but not of one with 256 bytes of EDATA, but that could be the reason. Erik
I am testing on an Intel 87C51. It's data sheet indicates that it is capable of addressing up to 64k of external data memory.
the memory device Is that "the memory mapped device" or "the memory" I think you should show your code, there is no obvious answer from the info you have provided. Erik
Here is the code requested. I left out the include files and ISRs. The serial port and timers are functioning as desired. I have tried both incrementing the address variable directly(code below) and using a #define statment to define it and adding an offset to it(shown in one of the app. notes). Both methods have the same result. The memory I refer to is the external memory mapped devices which is a UVPROM. unsigned int counter = 0; unsigned int address = 0x00; // 16 Bit Address where data is stored in the unsigned int temp_data = 0x00; // Data Byte Read unsigned char i = 0x00; P1 = 0x70; // Chip Select the UVPROM, High 8 Bits of 24 Bit Address for(i = 0; i<=8; i++) { printf("\n\rUVPROM Block 0x%bx",i); for(address = (i*0x0400); address <= (0x03FF+(i*0x0400)); address++) { temp_data = (XBYTE[address]); // Read data byte in from external UVPROM printf("\n\rAddress:0x%x, Data: 0x%bx",address,temp_data); } } P1 = 0x00; // Clear Port 1 after all the data is read while(1) { P1_0 = ~P1_0; // Toggle port pin } }
Are you sure that this meets the timing requirements of your memory-mapped thingy?
"unsigned int temp_data = 0x00;" Change that to unsigned char and it'll probably start working as you expect.
