Hello guys, When I download flash in Ram through ULINK Error comes LPC_IAP_256.flx "flash download fail" the same software when I download using UART works fine. What is worng ??? Is some file I am mising ?? can someone explain what is this error. I am using lpc2129. regards, Raheem
Mr. Reinhard, when I use GNU tool chain, my not only compile but also I can burn flash using ULINK. when I use keil tool chain I cannot download flash using ULINK. I correctly added startup file too according to the tool chain. then where am I doing wrong. regards, Raheem
Are you actually working with the Keil Development Suite for ARM V2.00? This version includes the SARM.DLL. I guess that you are using the 8051 tools which do not contian this DLL. You may download an evaluation version from http://www.keil.com/demo.
