Hello, i'm using die uvision2, cx51 7.2 for a philips mx chip. In my following example code, keil reserves data, which is assigned to registers und so furthermore not used. The problem only comes, when i'm using more params as can all be passed through registers. thanks for help, solving the problem. the .c file:
#include <REG51M.H> typedef unsigned char byteT; typedef unsigned int shortT; void test(shortT param1, shortT param2, shortT param3,shortT param4); shortT sub2(shortT param1, shortT param2 ); void main(void) { test(0x0011, 0x0022, 0x0033, 0x0044); while(1){} } void test(shortT param1, shortT param2, shortT param3,shortT param4) { shortT param5 =sub2(param1, param2)+ param3; param4++; } shortT sub2(shortT param1, shortT param2) { return param1+param2; }
FUNCTION/MODULE BIT_GROUP DATA_GROUP --> CALLED FUNCTION/MODULE START STOP START STOP ==================================================== ?C_C51STARTUP ----- ----- ----- ----- +--> ?PR?MAIN?MAIN MAIN/MAIN ----- ----- ----- ----- +--> ?PR?_TEST?MAIN _TEST/MAIN ----- ----- 0008H 0011H +--> ?PR?_SUB2?MAIN _SUB2/MAIN ----- ----- ----- -----
RSEG ?DT?_test?MAIN ?_test?BYTE: param1?140: DS 2 param2?141: DS 2 param3?142: DS 2 param4?143: DS 2 ORG 8 param5?144: DS 2 ; #include <REG51M.H> ; ; typedef unsigned char byteT; ; typedef unsigned int shortT; ; ; void test(shortT param1, shortT param2, shortT param3,shortT param4); ; shortT sub2(shortT param1, shortT param2 ); ; ; void main(void) RSEG ?PR?main?MAIN main: USING 0 ; SOURCE LINE # 9 ; { ; SOURCE LINE # 10 ; test(0x0011, 0x0022, 0x0033, 0x0044); ; SOURCE LINE # 11 MOV ?_test?BYTE+06H,#00H MOV ?_test?BYTE+07H,#044H MOV R3,#033H MOV R2,#00H MOV R5,#022H MOV R4,#00H MOV R7,#011H MOV R6,#00H LCALL _test ?C0001: ; while(1){} ; SOURCE LINE # 12 SJMP ?C0001 ; END OF main ; } ; ; void test(shortT param1, shortT param2, shortT param3,shortT param4) RSEG ?PR?_test?MAIN _test: USING 0 ; SOURCE LINE # 15 MOV param3?142,R2 MOV param3?142+01H,R3 ;---- Variable 'param2?141' assigned to Register 'R4/R5' ---- ;---- Variable 'param1?140' assigned to Register 'R6/R7' ---- ; { ; SOURCE LINE # 16 ; shortT param5 =sub2(param1, param2)+ param3; ; SOURCE LINE # 17 LCALL _sub2 MOV A,param3?142+01H ADD A,R7 MOV param5?144+01H,A MOV A,param3?142 ADDC A,R6 MOV param5?144,A ; param4++; ; SOURCE LINE # 18 INC param4?143+01H MOV A,param4?143+01H JNZ ?C0006 INC param4?143 ?C0006: ; } ; SOURCE LINE # 19 RET ; END OF _test ; ; shortT sub2(shortT param1, shortT param2) RSEG ?PR?_sub2?MAIN _sub2: USING 0 ; SOURCE LINE # 21 ;---- Variable 'param2?246' assigned to Register 'R4/R5' ---- ;---- Variable 'param1?245' assigned to Register 'R6/R7' ---- ; { ; SOURCE LINE # 22 ; return param1+param2; ; SOURCE LINE # 23 MOV A,R7 ADD A,R5 MOV R7,A MOV A,R6 ADDC A,R4 MOV R6,A ; } ; SOURCE LINE # 24 ?C0005: RET ; END OF _sub2
why on earth are you passing so much, it seems you think the '51 is a PC. Erik
to get reformed to '51 C from the PC style, read: http://www.esacademy.com/automation/docs/c51primer/ Erik
"... keil reserves data, which is assigned to registers und so furthermore not used. The problem only comes, when i'm using more params as can all be passed through registers." What are you saying the problems is -- that since some parameters happen to be allocated to registers because of the layout of your code, some memory locations are unused? If so, then add a call to some unrelated function (i.e., does not pass any of the "paramn" parameters) before the first call to sub2() in test(), and you'd likely see that all of those allocated parameter memory locations get used. What you are seeing now is the optimizer at work.
John, This may be a completely out of left-field guess, but there's some inconsistency with your code that might cause the compiler to try and figure out what you're doing. For instance, you're passing param4 by value, not by reference, so really, the line
param4++;
Thanks for your replies, but it ist not realy my problem. (Please, the code is only an example.) Im passing so many params, because i normaly have to do a call before test(), now i call it direct after entering test(), where i also use the correct param order to optimize code. you can see in the src file, that there is memory space reserved for param1 and param2
"So the reserved space for these params are not needed an never used." OK, then I accurately guessed what you perceive to be the problem. Now, why do you consider it to be a problem? Are you down to the last few remaining bytes in data memory and are running out? Is nothing else in your "real" code overlaying this area and therefore those couple of unused bytes are a concern?
