I am using the C167 with 4 IR sensors. They give an analogue output and i connected them to P5.0 of the C167. I used the MEASURE program from the kit's CD and is able to see the voltage changes on the C167 thru the debugger. By pressing 'R' the entire list of recorded voltages get displayed on the screen. However, i need these voltages to be stored somewhere in a text file, or to get MATLAB to read it. Can it be done? Really appreciate it if someone could help me. Regards, TH.
I do believe that MATLAB can collect data from a PC's serial ports - but that has nothing to do with Keil tools at all. You will need to consult your MATLAB Manuals, visit the MATLAB support site, see if you can find a MATLAB user forum, etc, etc,... At the embedded processor end, it is simply a standard UART IO task.
Yes Matlab can ne linked to varius resources, serial line included. We did a lot of experience with this in the past, if you are interested I can check for some examples.
Can you please enlighten me on how the C167 can be configured to continuously pump readings from port 5.0, 5.1, 5.2, 5.3 into MATLAB? How can MATLAB be configured as well? I would very very much appreciate it if you could give me some examples or instructions on how to do it.
The C167 knows absolutely nothing at all about MATLAB. Neither does it need to. You simply need to write C167 code to send the data to the UART. Depending on your specific requirements & target capabilities (about which we know nothing), this could be as simple as just printf.
What do I need to do in MATLAB then in order to read from the serial ports? I tried the function 's1=serial(COM1)', i didn't work, and i don't think it works that way.
What do I need to do in MATLAB then in order to read from the serial ports? Maybe you have to 1) Carefully read and understand the MATLAB MANUALS 2) Ask MATHWORKS SUPPORT for more help
"What do I need to do in MATLAB then in order to read from the serial ports?" This is a forum for discussing Keil sotfware tools. As has already been explained to you, MATLAB is not a Keil software tool: "MATLAB ... has nothing to do with Keil tools at all. You will need to consult your MATLAB Manuals, visit the MATLAB support site, see if you can find a MATLAB user forum, etc, etc,..."
If you want, drop an e-mail to my address and we can send you some info about how we did it. "stefano dot costa at bluewind dot it"
I search for link between matlab and keil or any way to programming Z-80 using matlab I thank you for your intresting and I sorry if you don't intresting that issue
Maybe this helps: http://www.keil.com/pr/article/1073.htm
