In my application, Main is an opcode handler which calls one of 10 functions based on a serial 0 opcode recieved. Main also defines an u_char InputArray[4] = {0xE2,0xFF,0xAA, 0xCC). One of the Opcodes calls a function which takes as an argument, a pointer to the above array. The function is supposed to send the 4 values in the array over the SPI as a master. What comes out instead is -> 0xE2, 0xAA, 0xCC, 0xCC. Here is the pertinent part of MAIN and the SPI handler function:
******************************************************************************/ #define _MSC1210_Recieve_ /***************************************************************************** Include */ #include "MSC1210_SPI.h" /***************************************************************************** Defines */ /***************************************************************************** Globals */ /***************************************************************************** Prototypes */ // Function Prototypes in MSC1210_SPI.h /***************************************************************************** MSC1210_SPI */ extern void MSC1210_SPI(unsigned char * pArrayStart) { ES = 0; // Disable Serial0 Interrupts P1DDRH = 0x75; // P1.4,5,7 = output; P1.6 = input PDCON &= 0xFE; // Turn on SPI SPIInit(); SPIDATA = *pArrayStart++; SPIDATA = *pArrayStart++; SPIDATA = *pArrayStart++; SPIDATA = *pArrayStart; while((AIE&0x04)!=0x04) { ;//Nothing, wait for SPIrx } PDCON ^= 0x01; // Turn off SPI ES = 1; }/* MSC1210_SPI */ /***************************************************************************** Functions */ // Function: SPIInit(void) // // Description: Setup portions of the SPI interface // which will not change when using different // Port1 functions // void SPIInit(void) { unsigned char data ClearFlags = 0x00; //SPICON -> 111x0110 = tclk/256,FIFO on, MSB first, Master, Valid on Edge, Idle Low SCLK SPIDATA = ClearFlags; ClearFlags = SPIDATA; SPICON = 0xF6; SPIRCON = 0x82; // Flush RXbuffer, 4 byte int SPITCON = 0xAA; // Flush TXbuffer, set SCLK drive, 4 byte int SPISTART = 0x00; SPIEND = 0x04; }/* SPIInit */ //############################################################################################## //############################################################################################## /***************************************************************************** Globals */ unsigned char data OpCode = 0x00; bit ChangeOp = 1; /***************************************************************************** Prototypes */ // Contained in MSC1210_MAIN.h /***************************************************************************** MAIN */ void MAIN(void) { static unsigned char data InputArray[] = {0xE2,0xF0,0xAA,0xCC}; const unsigned char data * pArray = &InputArray[0]; CKCON &= 0xf8; // 0 MOVX cycle stretch, timer1 clk/4, timer0 = clk/12 USEC= 10; // 11.8MHz Clock MSECH=0x07; // one millisecond high HMSEC=0x63; // one hundred millisecond interrupt MSC1210_Startup(); // Some basic Starup Initialization TI_0 = 0; EA = 1; // Enable Global Int while(1) // EOS Super Loop { // Running the Serial Interupt Opcode Handler switch(OpCode) { . . case 0x37: // "7" ChangeOp = 1; MSC1210_SPI(pArray); OpCode = 0x00; break; . . default: break; } }
I'll also add this: I've tried using different memory areas to store the array and pointer, but no change in the results. BTW: The device is a TI MSC1210y5
I am not familar with this CPU, But do you need to wait for the last byte to leave before sending the next byte?
The compiler uses ?C?CLDPTR and I'm not sure where to find its definition. This routine is a library routine. The naming convention indicates that it's "Character LoaD from (generic) PoinTeR". That is, it fetches the byte at a particular address. (Yes, that action requires an entire library routine to accomplish, not an instruction. Welcome to the 8051!)
The device has two SPI modes to choose from. 1. A double buffered mode - Two byte buffer, so you can write one byte prior to another's transmission, but you must watch flags so you don't overrun. 2. A selectable size FIFO. The FIFO can continually take bytes until it is full. The hardware deals with sending the data in the FIFO without overrunning the SPI interface.
It looks like you have selected already FIFO mode. However, I recommend that you put the initilziation at the start of 'main' rather then in the 'case' where you send the bytes.
If I weren't using Port1 for other things I would put it in my initialization function. However, GPIO and Ser1 are also being utilized at various times.
